Thread: Passkey III
Results 1 to 20 of 33
  1. #1 Passkey III
    SE Level Member Jeckel's Avatar
    Feb 2010
    Nampa, ID
    Is there a way to disable or bypass the passkey III on a 2000 GTP?
  2. #2 Re: Passkey III
    A tune might be able to shut off the VATS system.
  3. #3 Re: Passkey III
    Feb 2010
    Nampa, ID
    I haven't found anything in DHP to do that.
  4. #4 Re: Passkey III
    Apr 2011
    Elk Rapids, Michigan
    VATS can be turned off using HPtuners.
    2001 black GTP coupe, Gen V, ZZP S2IC & billet fuel rails, XP cam, LS7 lifters, 105# springs, ZZP MPS w/3.4 pulley, Northstar tb, LQ4 maf, ZZP headers, K & N CAI, Meziere electric wp, Caspers fp retire, F body front brakes, GMPP strut braces​, Don Rome strut brace mounts.
  5. #5 Re: Passkey III
    Did HPT finally fix it?
    In DHP there's a fuel pump or injector run time of 4 seconds. Changing that will keep the injectors from stopping
  6. #6 Re: Passkey III
    Feb 2009
    flintnasty MI
    Unlikely that a 2000 grand prix has theft prevention on the pcm. Most all grand prixs will run without the correct key and whatnot.
  7. #7 Re: Passkey III
    Feb 2010
    Nampa, ID
    Mine must be a factory freak then... I can only use the factory GM PK3 key in it... It will start, run for a few seconds (less than 4) and then die. So as unlikely as it might sound to you, I asked a question because I have an issue (I'm cheap and don't want to spend 35 bux on an extra key).
    Thank you ExLimey and Billboost, I will look at my tune with DHP and see what the run time is set to. Where is it located in HPTuners?
  8. #8 Re: Passkey III
    In HPT it's in the same area as fan speed and speed limiter. I forget..it's way to the right of the menus. However.. we didn't have the ability for the longest time to turn it off.
  9. #9 Re: Passkey III
    Donating Users timboku's Avatar
    Montgomery, IL
    Check out this item I found on eBay: http://pages.ebay.com/motors/link/?n...d=161305735806
    Only 13 bucks
    2002 GTP..DD.. Topswapped Gen V L26, XP cam, Full Size IC, E85, 2.6 Pulley,SD Headers, K&N Intake, N*/Lq4,FP Rewire, TEP Trans, F body Fronts, GXP Rear Brakes, LE Spoiler, AGXs with vogtland springs, bonni gxp rims, Timboku Tuned
    1995 Cutlass Supreme Convertible...Soon to be L32Swapped.....2005 GXP Stock
  10. #10 Re: Passkey III
    Jul 2010
    Coquitlam,BC,Canada
    Quote Originally Posted by Jeckel View Post
    Yes. Google the topic; vids galore.
    Chris B
    2009 CX-9
    ** SOLD ** 2002 GT
  11. #11 Re: Passkey III
    Jul 2010
    Coquitlam,BC,Canada
    Or does it.....
    Passkey III – transponder ignition key
    The Passkey III anti-theft system uses a transponder inside the head of the ignition key. Theexciter inside the ignition lock cylinder energizes this transponder when the ignition switch isturned on. The transponder transmits a unique signature to the theft deterrent control module.If the key signature transmitted is acceptable to the theft deterrent control module, the theftdeterrent control module will transmit fuel enable password to the PCM. If the fuel enablepassword is correct, the PCM will start the vehicle.
    Chris B
    2009 CX-9
    ** SOLD ** 2002 GT
  12. #12 Re: Passkey III
    SWPA
    Who said a PK3 key is $35? I think I paid $5 for my PK3 and paid nothing to get it cut at a local hardware store.
    eBay link for 2 for $11
    http://www.ebay.com/itm/like/1912579...lpid=82&chn=ps
    There are other options showing on that link where you can get them even cheaper.
  13. #13 Re: Passkey III
    Apr 2011
    Pretty sure you need a good PK3 key to program the new keys. The directions I got with the keys that I bought have you put the good key in the ignition, turn it on then off, put in the new unprogrammed key then turn the ignition on then off. If the OPs key is bad then he can't program the new key. The dealer may be the only option.
  14. #14 Re: Passkey III
    SWPA
    Quote Originally Posted by ExLimey View Post
    A locksmith can program it too.
  15. #15 Re: Passkey III
    And..if the ignition is bad and not reading the key.. then you need to bypass and stop worrying about keys.
    Bam.. take that key guys
  16. #16 Re: Passkey III
    Feb 2010
    Nampa, ID
    Quote Originally Posted by timboku View Post
    Only 13 bucks
    Contacted the seller, here is his response:
    Dear friend,
    I will send you self programming instruction with the keys if you need it, it is very easy as long as you have one working key (start the engine) the programming takes less then a minute. Just mention it when you do the checkout and I will make sure to add it to the keys.
    Also please make sure your vehicle is not made in Canada (VIN starts with the number 2) self programming isn't possible for Canadian vehicle.
    Thank you
    Ray S.
    Thanks! My thoughts exactly...
  17. #17 Re: Passkey III
    I had a local 02 that had the ignition issue. Programmed it out. Poof.. car started every time.
  18. #18 Re: Passkey III
    Feb 2010
    Nampa, ID
    How?
  19. #19 Re: Passkey III
    You do what I suggested in my first post.
  20. #20 Re: Passkey III
    i may have missed something, but why do you think its the key? it runs for a few seconds then stalls seems like a fuel pressure resistor gone bad.
  1. Passkey relearn 2006 gt
    By hulsizer70 in forum Introductions/Noob Questions
    Last Post: 10-25-2016, 07:19 AM
  2. passkey problem
    By GTP Ryan in forum General Tech Discussion
    Last Post: 07-21-2013, 10:06 AM
  3. passkey 3 issue
    By john cola in forum General Grand Prix Discussion
    Last Post: 07-06-2013, 01:23 AM
  4. HELP! Ignition Switch: Removing Passkey Module
    By Lawngoose in forum General Tech Discussion
    Last Post: 06-20-2009, 05:44 PM
  5. Q: PassKey III Relearn - Spare PCM
    By TommyGloves in forum PCM Tuning
    Last Post: 05-13-2008, 08:32 PM
