Thread: Tricks for removing LCA?
Results 21 to 40 of 43
  1. #21 Re: Tricks for removing LCA?
    Dec 2012
    Where 4T65E's were born
    You thought I was talking about end links? Lol no way man. I would cut links if they gave me any trouble.
    Sold.
  2. #22 Re: Tricks for removing LCA?
    GTP Level Member 04lss's Avatar
    Sep 2014
    Richmond Virginia
    I had to borrow a pickle fork and about an hour to get the ball joint to separate. My only problem is the Piston in the caliper wont move.
  3. #23 Re: Tricks for removing LCA?
    I soaked the **** out of the hokey puck bushing with pb blaster got sick of it and just cut the ****er off with the saws all lol.
  4. #24 Re: Tricks for removing LCA?
    Dec 2012
    The w body ball joints always come out real easy for me. And I'm in the salt belt. I take the nut most of the way off, pry between the CV shaft and nut , and it usually comes right off, then I remove the nut the rest of the way. I do put penetrating oil down the tapered fitting once the nut is loose. Seems to help consistently.
    Sold.
  5. #25 Re: Tricks for removing LCA?
    GT Level Member primem's Avatar
    Sep 2013
    Calgary, Alberta
    for separating stubborn lbj from the knuckle I loop a chain around the c/a near the bj. Then slide a long pry bar through the chain and wedge the tip under the subframe. I have someone push down on the prybar while I give the side of the knuckle taper a rap with the air hammer.
    2004 comp g
  6. #26 Re: Tricks for removing LCA?
    Enfield, CT
    Quote Originally Posted by primem View Post
    Holy **** thats more work than you need. Just get a BFH hit the lower part of the knuckle 1 or 2 times and the balljoint will drop then use a pry bar on the C/A to get the balljoint out of the knuckle
  7. #27 Re: Tricks for removing LCA?
    Moderator Russosaur's Avatar
    Apr 2012
    Dayton, OH
    I had to jam a screw driver in the hockey puck bushing because it just kept spinning and spinning.
    Ha you sucker sawing endlinks off. I turned mine a 1/8th turn and it broke into about 6 pieces.
    Sent from BFE
    2012 F150 STX
    - Gonna be a race truck
  8. #28 Re: Tricks for removing LCA?
    GT Level Member aligater's Avatar
    london ontario canada
    If the hockey puck bushing gets stuck to the bolt, get past the rubber part however you need to and find the split in the metal sleeve and use a chisel, air hammer or even a screw driver and hammer. Just got to open it ever so slightly and the bolt will come out.
  9. #29 Re: Tricks for removing LCA?
    Sep 2014
    Richmond Virginia
    I got a new set of end links for the sway bar, do i need anything off of the old one? it looks like theres a metal tube in the middle
  10. #30 Re: Tricks for removing LCA?
    Apr 2012
    Dayton, OH
    No it should come with everything you need
    Sent from BFE
    2012 F150 STX
  11. #31 Re: Tricks for removing LCA?
    Sep 2014
    Richmond Virginia
    Sent from BFE
    whats the order, one on the underside, 2, the tube, then another two?
  12. #32 Re: Tricks for removing LCA?
    Apr 2012
    Dayton, OH
    Found it, does this help?
    Sent from BFE
    2012 F150 STX
  13. #33 Re: Tricks for removing LCA?
  14. #34 Re: Tricks for removing LCA?
    Apr 2012
    Dayton, OH
    Only note i have the actually bushing upside down. Notice how one side has a like raised circular bit? That goes into the bar same for on the LCA, hope i explained that right
    Sent from BFE
    2012 F150 STX
  15. #35 Re: Tricks for removing LCA?
    Sep 2014
    Richmond Virginia
    Sent from BFE
    Yes! thanks!
  16. #36 Re: Tricks for removing LCA?
    Sep 2014
    Richmond Virginia
    Sent from BFE
    is it just the washer between the bolt head and the LCA? on the Old LCA there was a bushing of some sort.
  17. #37 Re: Tricks for removing LCA?
    the bushing go on top and bottom of the sway bar and the lca mount. see my pic up there.
  18. #38 Re: Tricks for removing LCA?
    Sep 2014
    Richmond Virginia
    Thanks, Its funny not having the right tools (picklefork, and c clamp) turned a 3 hour job into a 2 day job because i kept running around for tools.
  19. #39 Re: Tricks for removing LCA?
    BFH is all you need, and a saw to cut them end links off if they dont snap before they strip out.
  20. #40 Re: Tricks for removing LCA?
    Sep 2013
    Calgary, Alberta
    Quote Originally Posted by HighOctaneRacing View Post
    not when you live in the rust belt.
    2004 comp g
  1. INFORMATION Interior walkthrough tips & tricks
    By retrofit4gtp in forum Detailing Tips and Tricks
    Last Post: 08-19-2013, 09:04 PM
  2. tricks to rear subframe bushings?
    By Vegas~Blown in forum General Tech Discussion
    Last Post: 04-22-2013, 07:02 PM
  3. FWD Tricks
    By EJOUIE in forum Off Topic Discussion
    Last Post: 04-18-2012, 10:36 PM
  4. Stock Rebuild...advice? tricks?
    By ls1camino in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 11-10-2011, 06:49 AM
  5. Audio Wiring Tricks?
    By LuckyBambu in forum Audio, Security & Visual Electronics
    Last Post: 05-23-2010, 08:17 AM
