Thread: Tricks for removing LCA?
Results 1 to 20 of 43
  1. #1 Re: Tricks for removing LCA?
    GT Level Member primem's Avatar
    Sep 2013
    Calgary, Alberta
    for separating stubborn lbj from the knuckle I loop a chain around the c/a near the bj. Then slide a long pry bar through the chain and wedge the tip under the subframe. I have someone push down on the prybar while I give the side of the knuckle taper a rap with the air hammer.
    2004 comp g
  2. #2 Re: Tricks for removing LCA?
    Enfield, CT
    Quote Originally Posted by primem View Post
    Holy **** thats more work than you need. Just get a BFH hit the lower part of the knuckle 1 or 2 times and the balljoint will drop then use a pry bar on the C/A to get the balljoint out of the knuckle
  3. #3 Re: Tricks for removing LCA?
    Sep 2013
    Calgary, Alberta
    Quote Originally Posted by HighOctaneRacing View Post
    not when you live in the rust belt.
    2004 comp g
  4. #4 Re: Tricks for removing LCA?
    Enfield, CT
    I live in New England lol
  5. #5 Re: Tricks for removing LCA?
    Sep 2013
    Calgary, Alberta
    Its not for everyone. I found it to be a slick method with minimal hammer mashing. For some of the stuff I work on; they don't come out easy like wbodies designs.
    2004 comp g
  1. INFORMATION Interior walkthrough tips & tricks
    By retrofit4gtp in forum Detailing Tips and Tricks
    Last Post: 08-19-2013, 09:04 PM
  2. tricks to rear subframe bushings?
    By Vegas~Blown in forum General Tech Discussion
    Last Post: 04-22-2013, 07:02 PM
  3. FWD Tricks
    By EJOUIE in forum Off Topic Discussion
    Last Post: 04-18-2012, 10:36 PM
  4. Stock Rebuild...advice? tricks?
    By ls1camino in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 11-10-2011, 06:49 AM
  5. Audio Wiring Tricks?
    By LuckyBambu in forum Audio, Security & Visual Electronics
    Last Post: 05-23-2010, 08:17 AM
