Typically this is either the driver door switch for courtesy lights.. or a wire in the boot going to the door that has gotten broken. Those would be the first two things I'd be checking. And you could unplug door by door as you went to try and confirm it. Say you unplug all yoru doors and it still happens.. then you can move on to other stuff.
I also wouldn't say the BCM might not be bad and causing it.
