Thread: Blend door or actuator?
Results 1 to 12 of 12
  1. #1 Blend door or actuator?
    GTX Level Member EJOUIE's Avatar
    Newnan, GA
    How would I be able to tell the difference between a blend door being broken or stuck compared to the actuator going bad?
    97 GT white 4 door-SOLD
    Cherry 2005 Impala LS- Front and Rear GMPP Strut Tower Braces
  2. #2 Re: Blend door or actuator?
    GTP Level Member SnowDrift's Avatar
    Apr 2009
    Central Ohio map dot.
    locate the actuator you're questioning and operate the HVAC controls to see if the moving portion spins. If you can access one of them, take the actuator from another location in the car and swap them out to see if the problem goes away. Two are pretty easy to access - one on each side of the console up under the dash.
  3. #3 Re: Blend door or actuator?
    99% of the time the plastic gear in the actuator cracks and that makes the motor driving it slip. I'd bet toward the actuator, once you get to them though...you can actuate the door manually to ensure it's not broken.
  4. #4 Re: Blend door or actuator?
    Newnan, GA
    ^that might answer my question, but I was wondering if the symptoms would be any different.
  5. #5 Re: Blend door or actuator?
    Apr 2009
    It's most likely the motor if the door isn't operating. It's a quick check, really. Remove the panel above your feet on the driver side to access the underside of the dash. Look for the motor, turn the key on and operate the HVAC controls for the door and watch the motor to see if the gear is turning. If not, then take the motor out and try to operate the door manually. You're probably looking at 20-30 minutes if you've never gotten up there before. Maybe 5-10 minutes if you have. It's not a bad job.
  6. #6 Re: Blend door or actuator?
    Quote Originally Posted by EJOUIE View Post
    Screwed up temps.. yeah, both could. You'll be there looking at both either way.
  7. #7 Re: Blend door or actuator?
    Orlando,Florida
    I have a 97 grand prix gt non supercharged
    and the actuator on the passenger side is bad...I think doesnt turn
    so I took it out and unhooked the drivers side actuator and plugged the passenger one in and it didnt move so Im guessing the passenger one is bad
    not sure about the controls though..hope the passenger temp control is working
    I found different numbers on the pass vs the drivers actuator
    the drivers # is G3071683B the pass # is G307272A
    Hope they are interchangable
    someone on ebay said the are
    they sell alot of pontiac parts this one is 54.99 no tax and free shipping
    most places that I checked are 125.00 to 250.00 new
  8. #8 Re: Blend door or actuator?
    Apr 2009
    Quote Originally Posted by randy miller View Post
    Yup, a new OEM part will set you back over $100. I think I paid $117 for mine, but I knew I would get what I paid for.
  9. #9 Re: Blend door or actuator?
    Newnan, GA
    I can't seem to be able to get the bolts of of the metal piece that was behind the knee bolster. Anybody know what size socket will work?
  10. #10 Re: Blend door or actuator?
    Apr 2009
    7mm and/or philips is all that I seem to recall.
  11. #11 Re: Blend door or actuator?
    Newnan, GA
    metric system strikes again. I only have sockets in inches. But I was still able to access it without needing to take out the piece. Ran out of daylight, but I will try another crack at when time allows.
  12. #12 Re: Blend door or actuator?
    Dec 2011
    Delphos, Oh
    what do these look like and where exactly am i looking. i have hot air out of drivers side and cold out of passenger both are set on 60 degrees
    02 regal
    99 gtp
    01 gtp
  1. Blend Door Actuator Replacement
    By Abrasive in forum How To Write-Ups/Tech Tips
    Last Post: 08-02-2017, 04:59 AM
  2. Blend door
    By BADAZGTP in forum General Tech Discussion
    Last Post: 06-27-2016, 02:25 AM
  3. Blend Door
    By 98GTPON22s in forum General Tech Discussion
    Last Post: 03-07-2012, 09:50 PM
  4. Temperature Actuator
    By s7falcon in forum Shops and Community Heroes
    Last Post: 09-04-2009, 11:36 AM
  5. 97 grand prix gt 3.8 liter ac blend door actuator
    By king1997 in forum General Tech Discussion
    Last Post: 06-18-2009, 07:58 PM
