In case anyone else has this problem, I found the solution. If you remove the passengers sill plate, you will find the main harness run it split loom. Towards the front of the of the door, remove the harness from the split loom. There is a butt splice in there. Mine fell apart in my hands. I cut the wire back and installed a new butt splice and now all is well.
