Thread: Lighting issues
Results 1 to 5 of 5
NHRA21 Lighting issues 03-04-2012, 09:41 PM
jteske88 Re: Lighting issues 03-04-2012, 09:46 PM
NHRA21 Re: Lighting issues 03-04-2012, 10:16 PM
jteske88 Re: Lighting issues 03-04-2012, 11:04 PM
mikeygan17 Re: Lighting issues 03-07-2012, 09:52 PM
  1. #1 Lighting issues
    Donating Users NHRA21's Avatar
    Clinton, Ct
    I am having a couple of weird issues with my '00 GTP. The first is that not all the interior lights are coming on when I open the door. The lights in the footwells come on, but not the rest of them. The lights in the overhead console work manually. The second issue is with the headlights. I have installed a set of projector headlights with HID bulbs. When the headlights come on, both of the headlights don't always come on. When they dont, flipping the highbeams on and off solves the problem. Any ideas?
  2. #2 Re: Lighting issues
    Yoga city
    Do you have a harness on the hid's? As for interrior that a ringer!
  3. #3 Re: Lighting issues
    Clinton, Ct
    The HIDs plugged into the harness that was on the new headlight, and those harnesses plugged into the OE harness. No signs of melting.
    The interior is a ringer?
  4. #4 Re: Lighting issues
    Yoga city
    Voltage on the oem harness is known to have low voltage which causes you lights not come on, be dimmer, and flicker. And the ringer being I don't understand you interrior problem.
  5. #5 Re: Lighting issues
    Jun 2010
    ontario
    you need to install a relay, i had this problem when i first got my projectors with HIDs install the really and you should be good to go, and as for the interior lights, it might be you settings, if you look in your owners manual, you find a section under security options, you'll most likely want to set if to the 4 chime option (full security, lights flashes and the whole shabang- should be golden from there
  1. back lighting
    By dlk in forum General Grand Prix Discussion
    Last Post: 01-29-2012, 07:41 PM
  2. Lighting up the needles?
    By Grandprixfreak in forum Audio, Security & Visual Electronics
    Last Post: 12-20-2010, 10:34 AM
  3. Help with lighting please
    By sinceregtp in forum Visual/Body Modifications
    Last Post: 04-15-2010, 10:59 PM
  4. LIGHTING for an 04 GTP
    By ne04gtp in forum Shops and Community Heroes
    Last Post: 02-05-2010, 05:49 PM
  5. Lighting issues (again)
    By vailskier3 in forum Audio, Security & Visual Electronics
    Last Post: 09-17-2009, 07:03 AM
