Thread: Lighting issues
Results 1 to 11 of 11
  1. #1 Lighting issues
    Donating Users NHRA21's Avatar
    Clinton, Ct
    I am having a weird issue with my interior lighting. When you open the door, the dome lights do not come on, nor do the lights in the doors. The dome lights will come on when you press the button and the bulbs in the door lights test good. The lights under the dash do come on. This seemed to happen when I had the interior apart and replaced the dome light/sunroof switch assembly. I have tried switching back to the original one, but no change. Any ideas?
  2. #2 Re: Lighting issues
    St. Louis
    What year of GP are we dealing with?
  3. #3 Re: Lighting issues
    Clinton, Ct
    Sorry, my bad. It is a 2000 GTP. I wonder what happened to my sig...
  4. #4 Re: Lighting issues
    Clinton, Ct
    No ideas?
    2000 Grand Prix GTP that is wondering why the stage II heads and VS cam are still sitting on the shelf...
    Black - now with a black interior as well and gold badges.
    ZZP Stainless steel cat downpipe
  5. #5 Re: Lighting issues
    Clinton, Ct
    Ok, another question then. When the dimmer switch below the headlight switch is rotated all of the way to the right, the interior lights should turn on, including the overhead lights. Does it also turn on the lights in the doors?
  6. #6 Re: Lighting issues
    Moderator Russosaur's Avatar
    Apr 2012
    Dayton, OH
    The dimmer switch turns them on when all the way left not right if i remember right. Wish i could tell you on the door lights mine doesn't have any.
    Sent from BFE
    2012 F150 STX
    - Gonna be a race truck
  7. #7 Re: Lighting issues
    Mar 2014
    Tucson
    Quote Originally Posted by NHRA21 View Post
    Yup. All the way right does everything. Map lights, front floor lights, front door lights, and rear overhead lights.
  8. #8 Re: Lighting issues
    Apr 2012
    Dayton, OH
    Yeah I just thought and you were right so disregard my above comment
    2012 F150 STX
  9. #9 Re: Lighting issues
    Clinton, Ct
    I thought so. However, only the lights under my dash come on when I do this. I know there is a junction behind the passenger side B pillar cover. This connects the roof harness to the harness that runs under the carpet. It also has the backup lights in it. Because my backup lights work, I suspect this connection is good. I am betting there is another connection somewhere that connects the floor harness to the dash harness. Anyone know where this is?
  10. #10 Re: Lighting issues
    Clinton, Ct
    In case anyone else has this problem, I found the solution. If you remove the passengers sill plate, you will find the main harness run it split loom. Towards the front of the of the door, remove the harness from the split loom. There is a butt splice in there. Mine fell apart in my hands. I cut the wire back and installed a new butt splice and now all is well.
  11. #11 Re: Lighting issues
    Mar 2014
    Tucson
    Glad you got it fixed. No lights sucks. Especially since the days are getting shorter.
  1. LED Lighting
    By Youngster in forum Audio, Security & Visual Electronics
    Last Post: 07-21-2014, 10:51 AM
  2. Lighting Issues
    By Xanthous in forum General Tech Discussion
    Last Post: 09-07-2013, 07:56 PM
  3. Lighting issues
    By NHRA21 in forum Audio, Security & Visual Electronics
    Last Post: 03-07-2012, 09:52 PM
  4. Lighting issues (again)
    By vailskier3 in forum Audio, Security & Visual Electronics
    Last Post: 09-17-2009, 07:03 AM
