Thread: Old Thread
Page 2 of 2 FirstFirst 12
Results 21 to 29 of 29
  1. #21 Re: UPDATE: Need To Change My Oxygen Sensors And Catalytic Converter
    its 4 bolts, get under there and do it yourself, f the man!!!!!!
    grow a set of balls already.
    He doesn't work on his own car man if you've seen some of his old threads.. You'll know he's quick to pay someone instead of doing the work himself then complains about how this car is nickel and dimeing him.
    04 Comp G.
  2. #22 Re: UPDATE: Need To Change My Oxygen Sensors And Catalytic Converter
    i know his deal. its old. like i said, grow a set already.
    i was doing back brake jobs when i was 16. i didnt even have a car lol and those were all drum brakes. most are scared to death of them. not me. fronts were always easy to do.
    when a exhaust part simply unbolts,,,,,you get your ass under there and change it. its to damn easy to go pay a shop to do it.
    those gaskets you need are like 8 bucks each at any parts store. you may or may not need ne cat back bolts if they break. spray em down for a few days to help break em free. new bolts cost like a buck.
    if the upper bolts break, you drill it out and put a nut and bolt in. done deal. theres room to get the drill in there after the pipe is down.
  3. #23 UPDATE: Need To Change My Oxygen Sensors And Catalytic Converter
    Yup this whole catalytic converter thing can be a easy fix if he just nuts up and does the install his damn self instead of dropping I'm sure $500+ on what he's about to do.
    04 Comp G.
  4. #24 Re: UPDATE: Need To Change My Oxygen Sensors And Catalytic Converter
    drive to NJ find a shop there, its worth the tolls.
  5. #25 Re: What Is The Best Resonably Priced O2 Sensors and Catalytic Converters
    Jul 2010
    Coquitlam,BC,Canada
    Quote Originally Posted by Ginseng View Post
    .....because i wouldnt run the walker **** i sell because within 2 years it will have to be replaced again.
    Guess my 3 year old Walker cat is going to fail any day.
    Chris B
    2009 CX-9
    ** SOLD ** 2002 GT
  6. #26 Re: UPDATE: Need To Change My Oxygen Sensors And Catalytic Converter
    lol, what the hell happened in these two pages?
  7. #27 Re: UPDATE: Need To Change My Oxygen Sensors And Catalytic Converter
    you know damn well what happened lol
  8. #28 Re: Need To Change My Oxygen Sensors And Catalytic Converter
    Quote Originally Posted by SpeedGrid View Post
    Got some bad news.
    Went to a couple shops all which refused to install the catalytic converter due to NY state law.
    So I went to the guy I originally go to and had my car up on a lift and it turns out the oxygen sensors were bad as I expected. The rattling was coming from the heat shield on the exhaust and not the catalytic converter and he showed me under the car. He removed that and the rattling disappeared. He installed the new denso sensors and the readings came out fine. The car felt more responsive but he noticed the Catalytic converter was not up to par but was not awful and expected that for a car with over 80k miles but the o2 reading were back to normal.
    He said come back if there are any problems. I was charged $60 to install my o2 sensors.
    I drove for the rest of the day and the same P0420 code reappeared. Called him back up and said to bring the car back tomorrow so he can do a freeze frame and confirm if the converter is bad.
    If the converter is bad, I am going to have to order a GM original catalytic converter from the dealership which will cost nearly double of what I paid for the all in one from walker after the core charge.
    I sent back the walker catalytic converter today and hopefully should have my money back by Monday.
    What do you guys think guys is the catalytic converter defiantly the culprit? I have new sensors installed and the code reappeared. What else can cause a P0420 code?
    This really does suck.
    NY and California suck big time. Both listed as the most unfree states in the union. High taxes and tons of regulations as well.
    Once I get the money, I want to head over to Texas where there is much more freedom that NY and much better weather too.
    That is effn' BULL ****. I have a 3" downpipe going on my Saab in a few weeks while they do my clutch, it has what is advertised as a "Race Cat" it is definitely not Carb legal and my shop doesn't give a ****. Did this shop order this stuff for you?
  9. #29 Re: Need To Change My Oxygen Sensors And Catalytic Converter
    Jul 2010
    Coquitlam,BC,Canada
    Quote Originally Posted by Drunkie View Post
    The law does watch for this kind of activity. At my old shop, we had annual inspections, random inspections, and the tech doing the work was held accountable. I turned a lot of work away; my tech's job wasn't worth some kids desire to play race car.
    Chris B
    2009 CX-9
    ** SOLD ** 2002 GT
  1. Selling used catalytic converters
    By wags81 in forum Off Topic Discussion
    Last Post: 03-25-2014, 10:09 PM
  2. O2 Sensors & Catalytic Converter???
    By demetriuslopez in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 11-17-2010, 08:43 PM
  3. ZZP torque converters...
    By Tengis in forum 1997-2007 4 speed Automatic (4T65E) (4T65E-HD)
    Last Post: 01-07-2009, 11:22 AM
  4. Torque Converters...Which one??
    By japslpr in forum 1997-2007 4 speed Automatic (4T65E) (4T65E-HD)
    Last Post: 10-01-2008, 04:10 PM
