Thread: 2000 gtp idle problem ???!!!
Results 21 to 40 of 51
  1. #21 Re: 2000 gtp idle problem ???!!!
    and if you have a open cone and the pcm is kinda laying there like a lot of us do, check the wires to the pcm for a rubbed through wire. most of the time its near the a/c lines.
  2. #22 Re: 2000 gtp idle problem ???!!!
    SE Level Member GTPAIELLO's Avatar
    Aug 2012
    weymouth, ma
    15a
    2000 GTP - TURBO SETUP .
  3. #23 Re: 2000 gtp idle problem ???!!!
    i think its a 20 for that fuse. double check the box cover it should say what it should be.
  4. #24 Re: 2000 gtp idle problem ???!!!
    Aug 2012
    weymouth, ma
    I do have an open cone ,also the turbo is right there too! Def will look at that today ! I appreciate all the help guys
  5. #25 Re: 2000 gtp idle problem ???!!!
    im not so up on cold start turbos, not sure if you'll hear it through all that turbo pipping.
  6. #26 Re: 2000 gtp idle problem ???!!!
    turbo or super charger? super charger you'll hear it when cold, sound like crap. turbo not so sure, but i see ported sc in your sig.
  7. #27 Re: 2000 gtp idle problem ???!!!
    Aug 2012
    weymouth, ma
    Yeah my last one had the ported sc this one is turbo ,but yeah it idles like crap since the MAF stopped working
  8. #28 Re: 2000 gtp idle problem ???!!!
    Aug 2012
    weymouth, ma
    http://youtu.be/9EAd9uj6JUc
    link to engine idle video
  9. #29 Re: 2000 gtp idle problem ???!!!
    Aug 2012
    weymouth, ma
    Also lastnight i pulled the fuse box and inspected it for wiring smell and broken/damaged wires and found nothing .Tonight I will inspect the PCM wiring for damage and go from there. This thing is driving me nuts lol!
  10. #30 Re: 2000 gtp idle problem ???!!!
    HUDSON
    It sounds like there is a whistle, and that means vacuum leak.
  11. #31 Re: 2000 gtp idle problem ???!!!
    thats exactly what my car did when the fat evap line off the TB was cracked. surged 500 rpms up and down.
    try a 20 A fuse plug the maf back in and look for a vac leak if it still surges.
    the wires off the pcm should be looked at for one to have maybe been rubbed through if the fuse blows asap again.
  12. #32 Re: 2000 gtp idle problem ???!!!
    Aug 2012
    weymouth, ma
    The whistle is from the turbo , I looked on alldata at work today and it looks like the purge solenoid valve is on that same fuse ,so I will check that one out too
    Sent from my iPad using Tapatalk
  13. #33 Re: 2000 gtp idle problem ???!!!
    Aug 2012
    weymouth, ma
    Checked some more wires , can't find anything , getting close to just pulling the whole harness out and looking it over !!!
  14. #34 Re: 2000 gtp idle problem ???!!!
    Aug 2012
    weymouth, ma
    do you guys think it would be ok to use a circuit breaker where the fuse is supposed to be to make searching for the break easier? They sell a breaker that resets itself everytime it pops and it just fits right where the fuse would go.Obviously i wouldn't drive with it but as i'm searching the harness I can see when it pops and doesnt pop as i go throw the wires to see if i'm getting close to the problem instead of going through another box of fuses lol
  15. #35 Re: 2000 gtp idle problem ???!!!
    Jun 2012
    Ontario Canada
    I kept popping 15A fuses, realized I had spliced ACC power from something on the same circuit, put a 30 in there and it doesn't blow anymore
  16. #36 Re: 2000 gtp idle problem ???!!!
    Aug 2012
    weymouth, ma
    Yeah no matter what size I use it just blows it
  17. #37 Re: 2000 gtp idle problem ???!!!
    take that acc power tap you put on off. use a add a add a fuse to power it from the fuse box. then see if it blows the fuse with only what belongs on that fuse.
  18. #38 Re: 2000 gtp idle problem ???!!!
    Aug 2012
    weymouth, ma
    Acc power tap?wires anyone ?
  19. #39 Re: 2000 gtp idle problem ???!!!
    no, you said you added a power acc wire to the fuse for the maf, so take that wire off and find it a new power source is what im saying to do.
    while you got the harness all unwrapped check all them wires over good.
  20. #40 Re: 2000 gtp idle problem ???!!!
    Aug 2012
    weymouth, ma
    Oh that was xDony's post not mine
  1. 2000 GP GT stalls at idle
    By Mellsthatguy in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 08-20-2013, 10:01 PM
  2. 2000 Grand Prix Surging Idle Problem
    By robrileyw in forum General Tech Discussion
    Last Post: 05-12-2013, 08:35 PM
  3. checking senors for idle on 2000 3.8
    By pbob42 in forum General Tech Discussion
    Last Post: 03-18-2013, 07:19 PM
  4. 2000 GT Won't Idle
    By jefrowbe in forum General Tech Discussion
    Last Post: 09-26-2010, 07:31 AM
  5. 2000 GT Idle & Whine Issues
    By drewcruisin in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 01-12-2010, 10:53 PM
