Thread: Washer Pump Not Working
Results 1 to 2 of 2
  1. #1 Washer Pump Not Working
    Apr 2014
    Sumner, IA
    I bought my 08 Grand Prix wrecked in the right front. The wreck destroyed the washer bucket and pump. I put on a bucket and pump from an 04 but the plug was different, so I cut the the plug from the 08 off and wired in the one off of the 04. I currently can not get the washer pump to work. The wipers turn on, but no signal to the pump. I pulled the pump and connected direct to 12V and it works fine, but when I plug in and run the washers from inside the car, i can't get it to run. I test lighted the plug, and i have no power there when running the washers. Fuses are all good. I am thinking that I probably lost a ground somewhere due to the accident, but wanted some opinions on what else it might be.
  2. #2 Re: Washer Pump Not Working
    You have two wires, right.. power and ground
    If you test for power while using the battery negative as your ground, then you'll know if you have power. If you do a continutity test to ground, you'll know if you have that.
  1. Washer pump not working
    By camopaint0707 in forum General Tech Discussion
    Last Post: 06-21-2013, 06:21 AM
  2. Windshield Washer not working
    By trailshredder in forum General Tech Discussion
    Last Post: 01-30-2013, 04:48 PM
  3. washer fluid not working
    By 2000gtp8410 in forum General Grand Prix Discussion
    Last Post: 01-14-2012, 05:01 PM
  4. Windshield Washer not Working
    By JoshMcMadMac in forum General Tech Discussion
    Last Post: 06-02-2009, 06:08 PM
  5. Washer not working!
    By Dangerous313KidInAPrix in forum General Tech Discussion
    Last Post: 03-09-2009, 08:36 AM
