Clicks when turning are usually strut mounts going bad, did you replace them (correctly) when you did struts?
New strut assemblies - no shortcuts. I'm going to check that all bolts I touched are tight. The only uncertain thing was how tight to get my moog poly sway bar links. I didn't want to crush the poly bushings so I only guessed at how tight they should be ...
