Thread: Rear spring touching tire.
Results 1 to 6 of 6
  1. #1 Rear spring touching tire.
    GT Level Member chicagochuck's Avatar
    Aug 2012
    Chicago
    I have 2001 grand prix I guess its time for struts and springs. Last time I drove the car it was fine. Today I get in and hear a loud roaring noise as I drive. I check the wheels and the rear driver side spring is rubbing the top of the tire. The very bottom where the string starts is out of the strut and hitting the tire.
  2. #2 Re: Rear spring touching tire.
    sounds like the spring broke. someone else just had this problem not to long ago.
  3. #3 Re: Rear spring touching tire.
    HUDSON
    The spring broke. Does the car sagg in the front?
  4. #4 Re: Rear spring touching tire.
    yep broken spring.
  5. #5 Re: Rear spring touching tire.
    Aug 2012
    Chicago
    It doesn't sag in the front that I have noticed. But that sounds about right in regard to the potholes here, and I know I have hit some huge ones. I guess I know what my weekend will consist of. Thanks
  6. #6 Re: Rear spring touching tire.
    GTP Level Member
    Aug 2012
    st louis park, MN
    He said the rear spring is rubbing the tire. What does that have to do with the front end of the car? I would guess either the spring broke, as mentioned, or the spring broke through the bottom of the strut mount area. Something similar happened on my brother's Subaru . Good luck on repairs
  1. 1994 rear spring pad issue
    By bry412 in forum Brakes/Suspension/Chassis
    Last Post: 05-10-2011, 01:16 PM
  2. Rear tire wear
    By heavy duty in forum General Tech Discussion
    Last Post: 01-26-2011, 12:23 AM
  3. Rear Spring broke - 2000 GTP
    By Tfreeds in forum Brakes/Suspension/Chassis
    Last Post: 02-07-2010, 01:59 PM
