Thread: Power steering whine on left turns only...
Results 1 to 5 of 5
  1. #1 Power steering whine on left turns only...
    SE Level Member bentendo92's Avatar
    Aug 2008
    New Hampshire
    Strangest thing...
    My power steering pump seems to scream when making moderate to hard turns - LEFT only. Never have this issue turning right. Anyone have this or have an idea as to what could be the issue and why only in one direction?
    I'm also getting a loud "Clunk" or perhaps "Click" is a better way to describe when I turn the wheel. I read up on a TSB but wasn't sure if this was a critical issue or not....
    Thanks for any info.
  2. #2 Re: Power steering whine on left turns only...
    Aug 2008
    New Hampshire
    Probably helps if I give more info on the car, eh?
    2004 GTP...
  3. #3 Re: Power steering whine on left turns only...
    GT Level Member Preotic's Avatar
    Missoula, MT
    Perhaps you need a power steering fluid exchange. You put in new fluid and suck out the old. You do this back and forth(while moving wheel back and forth) until the stuff you suck out is as close to clear as you can get. I don't know how much it costs because once i befriended a GM Tech i forgot people pay for these things?.
    L26,Xp, zzp trans,3.29's,2700 conv, slp headers/catback, diy ported heads/LIM, 3 angle valve job,.052 MLS hg, outlet ported Gen V, 3.6, N*, LQ4, 4" FWI, agx's, ssc's, f-bodys, gmpp sway's +stb's
  4. #4 Re: Power steering whine on left turns only...
    Wichita, KS
    Or he could be low on fluid too. Or...its just the nature of the pump as some are louder than others.
    The clunk though...that would be something to be worried about.
    ~F~
  5. #5 Re: Power steering whine on left turns only...
    Aug 2008
    New Hampshire
    Yeah, the clunk is going to be looked at soon. I guess its an issue with the intermediate steering shaft which is quite common on the 04's and 05's...I guess they fixed it beyond that.
  1. Cubby hole to left of the steering wheel
    By RichCresci in forum Visual/Body Modifications
    Last Post: 01-29-2012, 12:47 AM
  2. Power Steering is SCREAMING. HELP A GIRL OUT!
    By Princess in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 07-23-2011, 11:16 PM
  3. Power Steering
    By SuperCharged6 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 07-31-2008, 05:01 PM
  4. Power Steering Rack replacement 98 GT
    By Fritcr in forum General Tech Discussion
    Last Post: 04-27-2008, 06:03 PM
  5. power steering
    By Toasty in forum General Tech Discussion
    Last Post: 02-23-2008, 01:24 PM
