Thread: need info and input on doing a swap on a series 3 05 grand prix to a supercharged
Results 21 to 40 of 41
  1. #21 Re: need info and input on doing a swap on a series 3 05 grand prix to a supercharged
    Jan 2014
    United States
    Quote Originally Posted by SnowTh1ef View Post
    I hate to disagree, but a topswap is much easier than an entire motor swap, and as zero reliability issues. Me and frosty95 are both running awesome topswap setups on stock trans.
    Did u have to run a custom tune with the stock trans or anything ?
    THE RIDES OF 2014​ 98' dodge ram 1500 sport/raminator-DD
    97' ford f-150 xlt-mud toy
    97' monte carlo z-34-project never to be done
    05' grand prix gxp-weekend warrior
  2. #22 Re: need info and input on doing a swap on a series 3 05 grand prix to a supercharged
    GT Level Member RivMan's Avatar
    Oct 2012
    Pinckney, MI
    You would have to run a Custom Tune for the Top Swap. You can use stock GT Transmission settings though if you're only doing a top swap.
    -Rob
    2004 GPGT - L32 Swap, CompG Trans - Click Here!
    1999 Regal - 300k miles: SOLD!
    1995 Riviera - L67 Swap, 12.9@107: SOLD!
    1999 GTP - 12.9@104: SOLD!
  3. #23 Re: need info and input on doing a swap on a series 3 05 grand prix to a supercharged
    Florida
    I don't doubt reliability on a topswap at all. I've done both, and I honestly found it easier and faster to swap a whole motor in, than to have to strip it down to the short block, and rebuild it up, all in the car. (which I just did for my GEN V swap/cam build)
    Just depends how experienced you are and how much access you have to the proper tools.
  4. #24 Re: need info and input on doing a swap on a series 3 05 grand prix to a supercharged
    Jan 2014
    United States
    he only has a plain jane grand prix not a gt, same trans i assume though?
  5. #25 Re: need info and input on doing a swap on a series 3 05 grand prix to a supercharged
    GTX Level Member SnowTh1ef's Avatar
    Aug 2013
    Sandy, UT
    Quote Originally Posted by LSFoFaSho View Post
    Yes same trans that year.
    04 GTP -HAI, 1.9 rockers.
  6. #26 Re: need info and input on doing a swap on a series 3 05 grand prix to a supercharged
    Aug 2013
    Sandy, UT
    Yeah thats a good point. To each his own haha. I just didn't have a cherry picker or anything, and was able to swap heads and all with pretty much a basic socket set and a breaker bar.
    Another good option would be an SSM90 setup, if he can find the modified rails and lower for sale, then he wouldn't need much at all.
  7. #27 Re: need info and input on doing a swap on a series 3 05 grand prix to a supercharged
    I Write E85 Stickies Frosty's Avatar
    Apr 2011
    South Dakota
    Can verify. Also dont bother swapping the wiring harness. The only differnece is the boost bypass valve solonoid wiring.... I haven't had the solonoid EVER and I have no issues. My BBV still works fine.
    "Lets just throw more boost at it and see what happens" -Frosty
    The Defacto Guide to tuning your car for E85. Read it and learn.
    I love Decker<3
  8. #28 Re: need info and input on doing a swap on a series 3 05 grand prix to a supercharged
    Oct 2012
    Pinckney, MI
    Quote Originally Posted by frosty View Post
    A GTP wiring harness also has 2 Pressure sensors, a 2 bar MAP and a baro sensor. Moving to a GTP harness / base cal requires the use of a GTP ABS module though.
    -Rob
  9. #29 Re: need info and input on doing a swap on a series 3 05 grand prix to a supercharged
    Apr 2011
    South Dakota
    Quote Originally Posted by RivMan View Post
    -Rob
    You may be correct but I'm saying that I don't have either of those and I'm running a gtp bin on my gt harness and have no issues.
  10. #30 Re: need info and input on doing a swap on a series 3 05 grand prix to a supercharged
    Aug 2013
    Sandy, UT
    I second this, running stock wiring harness, zero problems.
  11. #31 Re: need info and input on doing a swap on a series 3 05 grand prix to a supercharged
    Oct 2012
    Pinckney, MI
    What year car? The TCS system is completely different on an 04+ car.
    -Rob
  12. #32 Re: need info and input on doing a swap on a series 3 05 grand prix to a supercharged
    Aug 2013
    Sandy, UT
    Frosty and I both have pre-04, So I guess that could be a difference.
  13. #33 Re: need info and input on doing a swap on a series 3 05 grand prix to a supercharged
    Dec 2010
    ATL,Georgia
    -Rob
    Who wants the TCS on? Lol turn that **** off lol
    And ive been running a stock wire harness as well, you just have to get the Baro and MAP sensors and hook up the MAP to the lim and let the Baro see fresh air
    04 Top-swapped, 3.2 pulley, ZZP 1.9 rockers w/ #90 springs,Mild P&P heads, Pacesetter Headers, Sseilmnop 2" Phenolic Intercooler with stage 3 HE, ZZP billet fuel rails, 42.5lb injectors, 3" full exhaust, all poly mounts,other supporting mods.
    oh and weight addition mods: CTS-V brake upgrade, 14" GT500 rotors
  14. #34 Re: need info and input on doing a swap on a series 3 05 grand prix to a supercharged
    Oct 2012
    Pinckney, MI
    Quote Originally Posted by Alix0r View Post
    For me, it's the fact that if I'm swapping engines in a car, it damn well better be done right, and function like it left the Factory. Nothing annoys me more then a "Hillbilly hackjob" of a swap with a dash that lights up like a Christmas tree when you turn the key.
    Besides, TCS can be helpful over a Michigan winter.
    -Rob
  15. #35 Re: need info and input on doing a swap on a series 3 05 grand prix to a supercharged
    Dec 2010
    ATL,Georgia
    What mods you running? Cause my **** was squirlly as hell before i turned it off.. and just unplug the light lol.. it was almost to the point of being dangerous when i pulled out in traffic
  16. #36 Re: need info and input on doing a swap on a series 3 05 grand prix to a supercharged
    Aug 2013
    Sandy, UT
    Frosty tuned my TCS and it actually works incredibly well for me, and mine is not hacked together at all, everything works as is factory, and its really not a whole engine, just heads and SC.
  17. #37 Re: need info and input on doing a swap on a series 3 05 grand prix to a supercharged
    TC hasn't worked for me in idk how many years yea I could fix it easily but I prefer to do without it. To each it's own I guess.
    04 Comp G.
  18. #38 Re: need info and input on doing a swap on a series 3 05 grand prix to a supercharged
    Oct 2012
    Pinckney, MI
    Currently my car is "Stock". It stated life as an 04 GT, but it's currently setup as a GTP with a CompG trans.
    I can see the GT ABS system doing bad things with a top swapped car, but the GTP system is a lot more refined. The fact that it can dump boost where the GT system can't is a big factor.
    -Rob
  19. #39 Re: need info and input on doing a swap on a series 3 05 grand prix to a supercharged
    Aug 2013
    Sandy, UT
    It can if you can tune it right. Mine bonneville, which is just a lowly SLE has no problems reigning in the supercharged engine.
  20. #40 Re: need info and input on doing a swap on a series 3 05 grand prix to a supercharged
    Oct 2012
    Pinckney, MI
    Apples to Oranges comparison, the 04+ cars are completely different, and use the Throttle-By-Wire system extensively for Traction Control.
    -Rob
  1. supercharged motor swap 04 impala to 04 grand prix
    By alreadytooken in forum Engine
    Last Post: 05-12-2013, 10:49 PM
  2. Replies: 2
    Last Post: 09-28-2012, 01:19 PM
  3. 07 prix gt pcm swap. Need info
    By szalajka05 in forum General Tech Discussion
    Last Post: 04-01-2012, 04:04 AM
  4. swap a series 2 supercharged motor for a series 3 supercharged into my 2000 gtp
    By 2000GTPGUY in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 01-21-2012, 04:26 PM
  5. 1997 Pontiac Grand Prix to Supercharged engine swap
    By 1997GSX in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 06-28-2010, 08:00 AM
