Thread: Timing Chain/Belt replacement? Tension-er replacement?
Results 1 to 4 of 4
  1. #1 Timing Chain/Belt replacement? Tension-er replacement?
    SE Level Member void33's Avatar
    Jan 2013
    Chicago
    2000 Grand Prix GT @ 210,000
    I am wondering if my engine has a timing belt or a timing chain and also if I should replace it. I figure if it's a chain it will last much longer than a belt, but I am at 210,000 miles so won't it wear and stretch eventually? Also I know that the tensioners wear down over time, should I replace that?
  2. #2 Re: Timing Chain/Belt replacement? Tension-er replacement?
    GTX Level Member SnowTh1ef's Avatar
    Aug 2013
    Sandy, UT
    You have a chain, and unless you are running a crazy cam or springs, it very rarely, if ever needs replaced. Search and google are you friends.
    04 GTP -HAI, 1.9 rockers.
  3. #3 Re: Timing Chain/Belt replacement? Tension-er replacement?
    St. Louis
    If it's not making noise, leave it alone. These motors can go well into the 200K range and beyond on a stock chain. If it ain't broke, don't fix it.
    If you haven't ever changed the LIM gaskets on that motor, then now would be a good time before it lunches the motor from eating coolant. Only then would I suggest a timing chain AND gear replacement since you are almost there during the LIM gasket job.
    Here is a link that may help you should you decide to go that route--> http://www.grandprixforums.net/threa...g+timing+chain
  4. #4 Re: Timing Chain/Belt replacement? Tension-er replacement?
    I Write E85 Stickies Frosty's Avatar
    Apr 2011
    South Dakota
    Im running 105lb springs on a stock 170k chain and tensioner. *crosses fingers*
    "Lets just throw more boost at it and see what happens" -Frosty
    The Defacto Guide to tuning your car for E85. Read it and learn.
    I love Decker<3
  1. timing chain replacement
    By joeybtlr in forum Introductions/Noob Questions
    Last Post: 01-15-2013, 08:33 PM
  2. Oil Pressure Light On After Timing Chain Replacement
    By Scott Kane in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 12-04-2010, 10:00 PM
  3. Timing Chain Replacement How To?
    By guitarguyucf in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 08-17-2010, 09:25 PM
  4. Timing Chain Replacement
    By Traeger2591 in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 06-07-2010, 12:11 PM
  5. timing chain replacement question
    Last Post: 05-27-2010, 08:53 PM
