Thread: Full guage shows full when it's 1/8th tank - car won't start?
Results 1 to 20 of 25
  1. #1 Full guage shows full when it's 1/8th tank - car won't start?
    May 2008
    Florida
    PROBLEM FIXED = BAD PCM
    2000 GTP
    Went to go start my car today, and it would crank, but not start. Typically it starts in just a bump of the key. I noticed the gas gauge read full, yet the digital display showed 0 mi left.
    Car was low on gas (1/4-1/8 left) a week or so ago, so not sure why it would show full?
    Wondering if I had a gas theft or evaporation somehow? Thinking of filling up a 5 gal with 93 and seeing if that is the problem.
  2. #2 Re: Full guage shows full when it's 1/8th tank - car won't start?
    they this for the no start.
    has the car been sitting a while? the gas lever may be stuck, or the sender on the pump took a dump, its fixable for about 20 bucks or so.
  3. #3 Re: Full guage shows full when it's 1/8th tank - car won't start?
    May 2008
    Florida
    I try to drive it once a week or so, it started fine just last week. I thought it was very strange that both the fuel guage jumped to full as well as the no start condition happened a the same time.
    Is there a trick to the full pump resistor, or simply check/replace it?
  4. #4 Re: Full guage shows full when it's 1/8th tank - car won't start?
    if doing the bent tab on the relay works its the resistor, its in the fender by the battery.
    if it dont work, test the valve on the fuel rail for fuel pressure. key set to run. if nothing comes out the pump is bad.
    put a rag over the valve then push the pin in with a screw driver, fuel should spray out with some force, watch your eyes.
    id check the fuse boxes also for a bad fuse.
  5. #5 Re: Full guage shows full when it's 1/8th tank - car won't start?
    oh, and then theres the bang on the gas tank bottom trick if theres no pressure. sometimes a little beating makes it work again for a while. if it does fire up the pump is bad.
    also check for spark. you can take the plug wire off the coil, prop it a inch over the terminal crank the engine, a spark should jump to the wire.
  6. #6 Re: Full guage shows full when it's 1/8th tank - car won't start?
    May 2008
    Florida
    Quote Originally Posted by Y2KGTP View Post
    Found it, no go still won't start. I'll throw some gas in it tomorrow just to make sure.
  7. #7 Re: Full guage shows full when it's 1/8th tank - car won't start?
    May 2008
    Florida
    Thanks, I'll dig threw this in the AM as it's getting dark out shortly.
  8. #8 Re: Full guage shows full when it's 1/8th tank - car won't start?
    May 2008
    Florida
    Fuel relay tab did not help so put it back. Got Spark. When I check the pressure valve I only get a tiny blip of gas onto a rag.
    If I crank it for a few seconds, then stop and check the valve, no gas comes out.
    I am trying to figure out what would cause the gas guage pegged at full as well as the low fuel pressure?
    EDIT
    As the sender is part of the fuel pump assembly?
  9. #9 Re: Full guage shows full when it's 1/8th tank - car won't start?
    May 2008
    Florida
    Next day or so I will pull out the back seat and check for power to the pump, else I am thinking it just went bad.
  10. #10 Re: Full guage shows full when it's 1/8th tank - car won't start?
    the trap door for the fuel pump is in the trunk.
    sounds like the pump took a crap on ya. you try pounding on the bottom of the tank with your palm? you hear it prime? as you turn the key to run listen in the trunk or open the back seat to hear better for a buzz, it only lasts up to 5 seconds after you turn the key to run.
  11. #11 Re: Full guage shows full when it's 1/8th tank - car won't start?
    GTP Level Member Twizted 1's Avatar
    Jul 2013
    Summertown Tn
    Why would you pull the back seat out?
    Just pull the trunk carpet up and take the inspection plate off.
    When you turn the key to the on position can you hear the pump run?
    Also, hold your hand on the relay pictured above and have a friend turn the key to the on position and see if the relay clicks.
    Sent from Not so smart smartphone
  12. #12 Re: Full guage shows full when it's 1/8th tank - car won't start?
    May 2008
    Florida
    Quote Originally Posted by Twizted 1 View Post
    I have a 2-12 sub box back there, I mounted it so it just clears the pump access a while back.
  13. #13 Re: Full guage shows full when it's 1/8th tank - car won't start?
    May 2008
    Florida
    Car actually started today as normal, so I was pretty sure it's the pump going bad as it sat for a couple weeks. Swapped in a new Airtex unit, and good to go.
    Was nice just to have to access via the ski pass threw to get to the pump. That retaining ring was a PITA on the other hand to get back on.
  14. #14 Re: Full guage shows full when it's 1/8th tank - car won't start?
    May 2008
    Florida
    And....I am back to the initial problem. Fuel Guage pegged at 100%, and no start....just cranks.
    EDIT:
    Add that voltage seems to be around 1.70v at the (Sender wiring), bumps to 1.8v when cranking......
  15. #15 Re: Full guage shows full when it's 1/8th tank - car won't start?
    May 2008
    Florida
    Well, got a bit further. The below is for the upgraded harness that came with my pump.
    Black/white = Sender Ground
    Purple = Sender Signal
    Black = Pump Ground
    Gray = Pump Power
    When I have a meter on the pump wiring, turning the ignition on gives me about 9v to the pump for a second or so to prime. Cranking shows zero voltage.
    Now it has as same symptoms as before I replaced the pump (gas gauge pegged 100% - crank no start)
    Just before I replaced the pump, for giggles I tried to start the car, and it did. I replaced the pump regardless as could have been bad, and the wife reported the car was surging a bit when she last drove it.
    I tried the resistor bypass on the replay (resistor was replaced a few years back), as well swapped both relays around, and 15A fuse is good.
    I am getting power to prime the pump, but no voltage when cranking.
  16. #16 Re: Full guage shows full when it's 1/8th tank - car won't start?
    May 2008
    Florida
    One thing I thought was interesting, is that I only saw 9v at the pump when priming with the key on.
    Should this be 12v?
    Hopefully will test the pump relays later today, but I don't see how this would effect the fuel gauge pegged at 100%. For almost 2 weeks it ran just fine on the new pump (gas gauge worked as well), then poof, back to the original issue.
  17. #17 Re: Full guage shows full when it's 1/8th tank - car won't start?
    May 2008
    Florida
    Both relays 'click' when I jumper them on my bench.
    Wonder if it's worth just pulling the negative from the battery for a few hours? I don't see how the fuel gauge and the no voltage to the pump problems happen at the same time.
  18. #18 Re: Full guage shows full when it's 1/8th tank - car won't start?
    May 2008
    Florida
    Got my Bluetooth OBD2 adapter, so figured I would see if any stored codes, nope.
    Tried to start, and it fired right up, as well as the Fuel gauge was back working correctly as well. Extremely frustrating.
    I really don't want to drive it as no idea when it will act up again.
  19. #19 Re: Full guage shows full when it's 1/8th tank - car won't start?
    starting to sound like a crank sensor. they like to work when they see fit when they go bad.
    it ever just stall for reason driving down the road in the past? and then fire right back up?
  20. #20 Re: Full guage shows full when it's 1/8th tank - car won't start?
    May 2008
    Florida
    I replaced that a few years ago when I had the wandering Speedo.
  1. The gas tank thinks it's full, but it's not?????
    By ThaUnknownOne in forum 5.3L V8 (LS4)
    Last Post: 01-06-2014, 01:25 PM
  2. Full tank of fuel gauge floats between full and empty.
    By johnnyb in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 03-23-2013, 06:17 PM
  3. F250 vs GTP or Damn it! I had almost a full tank of gas in there.
    By rcktmn455 in forum General Grand Prix Discussion
    Last Post: 05-23-2012, 11:49 AM
  4. better gas mileage when tank is full/almost full
    By azmattaz06 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 06-07-2010, 09:53 AM
  5. Gas guage stays on full.
    By spiritwolf05131968 in forum Audio, Security & Visual Electronics
    Last Post: 03-21-2009, 09:35 PM
