Thread: Full guage shows full when it's 1/8th tank - car won't start?
Page 2 of 2 FirstFirst 12
Results 21 to 25 of 25
  1. #21 Full guage shows full when it's 1/8th tank - car won't start?
    May 2008
    Florida
    Car would not start today, but was fine a week ago. I hooked up my OBD2 bluetooth adapter, and it could not connect to the ECU per the warning in the app. Tested it on the wife's van and it connected just fine.
    When I got the adapter a few weeks ago it connected just fine and no codes were reported.
    Thinking either faulty ECU or wiring ?
    I also read some similar symptoms pointing to a bad ignition switch as well.
  2. #22 Re: Full guage shows full when it's 1/8th tank - car won't start?
    check the fuse box, for blown fuse, the cig lighter fuse. or power port, same thing.
  3. #23 Re: Full guage shows full when it's 1/8th tank - car won't start?
    May 2008
    Florida
    Late reply, tied up with work.
    All fuses are fine.
    Checked car again today, and fuel gauge was normal, OBD2 could scan (no codes found) and car starts fine.
    Whatever the problem is, it affects all 3 of these areas at once. I pulled the PCM out and checked for any frayed or chewed wires, but could not find anything.
    These are the current symptoms when the no-start condition shows itself:
    - Fuel gauge pegged at Full
    - No voltage goes to pump during cranking, but primes fine when key is turned on.
    - OBD2 port will not connect.
    Simply letting the car sit for a week was the only thing 'done' when it was not starting, to working just fine.
  4. #24 Re: Full guage shows full when it's 1/8th tank - car won't start?
    May 2008
    Florida
    Just an update, the car appears to start fine every time the past few months, however it is not driven much at all. I went to start it today, and noticed the fuel gauge pegged at full, and fluctuating slightly (car has 1/2 tank). Also, car would barely move until 2500rpm.
    Codes pulled showed the following, so I am guessing it is stuck in 3rd gear.
    p0753 1-2 shift solenoid
    p0758 2-3 shift solenoid
    Think all of these issues (starting\fuel gauge\trans codes) could be traced back to a bad PCM?
  5. #25 Re: Full guage shows full when it's 1/8th tank - car won't start?
    May 2008
    Florida
    Problem Solved = bad PCM.
  1. The gas tank thinks it's full, but it's not?????
    By ThaUnknownOne in forum 5.3L V8 (LS4)
    Last Post: 01-06-2014, 01:25 PM
  2. Full tank of fuel gauge floats between full and empty.
    By johnnyb in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 03-23-2013, 06:17 PM
  3. F250 vs GTP or Damn it! I had almost a full tank of gas in there.
    By rcktmn455 in forum General Grand Prix Discussion
    Last Post: 05-23-2012, 11:49 AM
  4. better gas mileage when tank is full/almost full
    By azmattaz06 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 06-07-2010, 09:53 AM
  5. Gas guage stays on full.
    By spiritwolf05131968 in forum Audio, Security & Visual Electronics
    Last Post: 03-21-2009, 09:35 PM
