Thread: Drivers window switch works backwards??
Results 1 to 5 of 5
  1. #1 Drivers window switch works backwards??
    SE Level Member jamez74's Avatar
    Jan 2013
    Medicine Hat, Alberta
    Up is down and down is up lol. The passenger window works fine. I just bought this car not to long ago and noticed in the glove box a receipt for a window regulator. Is it possible the regulator was plugged in backwards or something? I would think not but I know the switch cannot be plugged in wrong so I am unsure what else it could be.
    Ideas, suggestions would be appreciated.
    Thanks.
  2. #2 Re: Drivers window switch works backwards??
    i would open the door and check the wires, you never know. does sound like its wired backwards.
  3. #3 Re: Drivers window switch works backwards??
    St. Louis
    I've had this happen w/ aftermarket regulators/motors (2 in fact). Just pull the door panel and switch the 2 wires around at the motor plug. Problem solved.
  4. #4 Re: Drivers window switch works backwards??
    Jan 2013
    Thanks, I will have to try that. I just had the door apart earlier today and didn't even think to look at that. Just put all new pins in and put it back together lol.
  5. #5 Re: Drivers window switch works backwards??
    good news is you know how to get the door skin off now lol second time is super easy.
  1. drivers side 2 door window switch!
    By 16MustangVet in forum Wanted To Buy - Parts
    Last Post: 06-20-2012, 05:24 PM
