Honda and the DOHC head design on the vtec models if not maintained with proper valve lash adjustments they will burn valves. If the previous owner was out beating on it and lost the timing belt = valve train to piston damage. All of the honda vtec models are interference design. But as said it is normal to a point for these to burn oil, The valve guides, valve seals leak after time due to higher revs.
