Thread: Compression Test
Results 1 to 12 of 12
  1. #1 Compression Test
    SE Level Member RedGrandPrix's Avatar
    Aug 2008
    California
    I had the car compression tested today:
    1999 Pontiac Grand Prix GTP 109,000 miles
    #1 130 psi
    #2 150 psi
    #3 130 psi
    #4 145 psi
    #5 140 psi
    #6 150 psi
    Are these numbers good or bad?
  2. #2 Re: Compression Test
    Banned - Busted For Scamming
    Feb 2009
    they look fine to me, is it running poorly or something?
  3. #3 Re: Compression Test
    Aug 2008
    California
    I wanted to check the condition of the motor before I continued to spend money on mods.
  4. #4 Re: Compression Test
    As long as they all around around 10-20psi within each other it is supposed to be in great running shape IMO. Seafoam it...then test it again and see if it becomes even more consistant of a psi.
  5. #5 Re: Compression Test
    Aug 2008
    California
    I heard it had to be within 10%
  6. #6 Re: Compression Test
    well, 10% of 150 is 15...so that would give you a lee-way of 135-150, so you are like what? 2% ish difference on 2 pistons...like I said, seafoam it and it should all be good to go
  7. #7 Re: Compression Test
    TDCRacing
    Guest
    Those numbers are fine. Good to go.
  8. #8 Re: Compression Test
    You don't mention if this is with the throttle blocked open, all plugs out and whether you added a little oil for the wet check as well.
    There are sometimes many factors that can affect a compression test. Overall your results look good though. Maybe retest those lower cylinders and see if you get a slightly different number.
  9. #9 Re: Compression Test
    TDCRacing
    Guest
    Some good points Bill.
  10. #10 Re: Compression Test
    Wausau, WI
    yes those are some good points............what is the proper procedure for doing a compression test? Or is there a thread out there already that I missed?
  11. #11 Re: Compression Test
    Moore, Oklahoma
    Quote Originally Posted by Liquifire View Post
    I'm curious too. I think i've done it one plug at a time, I can't remember though......
    Shawn W. Larsen
  12. #12 Re: Compression Test
    Wausau, WI
    right.......it is one plug at a time......but are the other plugs all in? anything special done with the intake region? Etc......????
  1. compression check
    By justwhisen in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 07-06-2009, 10:09 PM
  2. Compression Check?
    By 99prixgt in forum General Tech Discussion
    Last Post: 06-09-2009, 11:01 AM
  3. Bad Compression?
    By comongoose in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 02-24-2009, 01:22 AM
  4. Video Compression Question
    By GeddyLee in forum Off Topic Discussion
    Last Post: 03-03-2008, 06:15 PM
