Thread: Compression test results
Results 1 to 16 of 16
Nickell Compression test results 11-27-2013, 06:43 PM
primem Re: Compression test results 11-27-2013, 07:01 PM
Nickell Re: Compression test results 11-27-2013, 08:40 PM
00grandprixgtp Re: Compression test results 11-27-2013, 09:49 PM
Nickell Re: Compression test results 11-28-2013, 12:19 AM
primem Re: Compression test results 11-28-2013, 08:59 PM
ericspecullaas Re: Compression test results 11-28-2013, 12:21 AM
00grandprixgtp Re: Compression test results 11-28-2013, 12:21 AM
00grandprixgtp Re: Compression test results 11-28-2013, 12:23 AM
Nickell Re: Compression test results 11-28-2013, 12:24 AM
00grandprixgtp Re: Compression test results 11-28-2013, 12:28 AM
osiris94ej Re: Compression test results 11-29-2013, 01:09 AM
Nickell Re: Compression test results 11-29-2013, 05:29 PM
Nickell Re: Compression test results 12-01-2013, 07:10 PM
primem Re: Compression test results 12-01-2013, 11:02 PM
Nickell Re: Compression test results 12-02-2013, 08:23 PM
  1. #1 Re: Compression test results
    Donating Users Nickell's Avatar
    Dec 2008
    Cedar Rapids, IA
    not normal to burn 2 1/2 qts in 2k miles...
    shop said probably a burnt valve or/and bad head gasket
    1998 GP Daytona - PLOG, 104's, PRJ Wires, Lucas 42.5's, DHP 1.0 Tune, DP, Full Borla, GPO's, Roof Rails, Gen 2 Spoiler, 04+ Needles, Menards Intake, 3.5 Pulley, SSC Springs, Corn-fed
    2000 Bonneville SSEI - 212k+, New Gaskets and Stuffs
  2. #2 Re: Compression test results
    GT Level Member primem's Avatar
    Sep 2013
    Calgary, Alberta
    Quote Originally Posted by Nickell View Post
    compression sure jump up alot for the wet tests. Leakdown test will give you the answers you need.
    2004 comp g
  1. Compression test results?
    By Jcinstalls in forum 3.1L V6 (LHO/LG8)
    Last Post: 04-05-2015, 10:58 AM
  2. Torque App Sensor Test Results
    By Thompsju in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 11-13-2013, 02:07 PM
  3. Compression test procedure?
    By Elite6 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 08-08-2013, 09:42 PM
  4. Did a compression test today...
    By Iron Indian in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 10-03-2009, 09:37 AM
  5. Compression Test
    By RedGrandPrix in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 07-28-2009, 10:38 PM
