Thread: Compression test procedure?
Results 1 to 5 of 5
Threaded View
Elite6 Compression test procedure? 08-08-2013, 01:51 PM
ericspecullaas Re: Compression test... 08-08-2013, 01:56 PM
Elite6 Re: Compression test... 08-08-2013, 01:59 PM
ericspecullaas Re: Compression test... 08-08-2013, 02:01 PM
Z34Phoenix Re: Compression test... 08-08-2013, 09:42 PM
  1. #1 Compression test procedure?
    Cambridge, Ontario Canada
    Been searching around with some luck, i want to confirm if this procedure is correct or not
    1. Remove electrical connector from the coil pack area - I think its called the ICM connector?
    2. Disconnect fuel pump fuse
    3. Block TB open
    4. Do one cylinder at a time
    5. Other cylinders have plugs installed & wires connected
    6. Crank over car 5 times per cylinder
    Is that correct?
    2005 E55 - stock
  1. Compression test results?
    By Jcinstalls in forum 3.1L V6 (LHO/LG8)
    Last Post: 04-05-2015, 10:58 AM
  2. high compression, low boost. lower compression, higher boost
    By BlackGT97 in forum General Tech Discussion
    Last Post: 08-25-2011, 11:52 AM
  3. Procedure for dropping the oil pan on GTP?
    By anicolay in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 07-12-2011, 06:18 PM
  4. Did a compression test today...
    By Iron Indian in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 10-03-2009, 09:37 AM
  5. Compression Test
    By RedGrandPrix in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 07-28-2009, 10:38 PM
