Thread: Compression test results
Results 1 to 16 of 16
  1. #1 Compression test results
    Donating Users Nickell's Avatar
    Dec 2008
    Cedar Rapids, IA
    Heres what my honda turned up
    Dry test - 155 180 185 180
    Wet test - 200 240 240 235
    155 compression seems pretty good still honestly, and the jumps from dry to wet test were consistant so im leaning towards rings being alright.
    Any other thoughts?
    1998 GP Daytona - PLOG, 104's, PRJ Wires, Lucas 42.5's, DHP 1.0 Tune, DP, Full Borla, GPO's, Roof Rails, Gen 2 Spoiler, 04+ Needles, Menards Intake, 3.5 Pulley, SSC Springs, Corn-fed
    2000 Bonneville SSEI - 212k+, New Gaskets and Stuffs
  2. #2 Re: Compression test results
    GT Level Member primem's Avatar
    Sep 2013
    Calgary, Alberta
    the dry reading don't seem low but the compression jumped up quite a bit for the wet test. How much oil did you add?
    17%lower is probably right on the edge of allowable.
    maybe a cylinder leakdown test would be in order.
    were you having any issues?
    2004 comp g
  3. #3 Re: Compression test results
    Dec 2008
    Cedar Rapids, IA
    added a oil bottle cap of oil. smoking out of exhaust
  4. #4 Re: Compression test results
    GT Level Member 00grandprixgtp's Avatar
    Apr 2009
    Elkhart
    lol its a Honda that is normal
    2.4Pulley, Ngk Tr7 plugs, Self tune, Methanol injection
    23.5 deg timing gen v,78mm billet tb , Poly dog mounts, Sd headers
    Zzp s2 intercooler ,UD wp pulley,is2cam,130# springs modded retainers
    P&P heads and lim built trans 3.29 gears harden parts 2500 stall shift kit
  5. #5 Re: Compression test results
    Dec 2008
    Cedar Rapids, IA
    not normal to burn 2 1/2 qts in 2k miles...
    shop said probably a burnt valve or/and bad head gasket
  6. #6 Re: Compression test results
    Feb 2013
    37.295091, -121.930053
    So you only did 4 of the 6 cylinders?
    im a cookie again yay me
    please learn to forum better.
    ^^new favorite quote
  7. #7 Re: Compression test results
    Apr 2009
    Elkhart
    Lol once again all normal for a honda
  8. #8 Re: Compression test results
    Apr 2009
    Elkhart
    If it doesnt look like a fog machine then it prob a new honda but just wait disco is coming
  9. #9 Re: Compression test results
    Dec 2008
    Cedar Rapids, IA
    not with 80k it shouldent lol
  10. #10 Re: Compression test results
    Apr 2009
    Elkhart
    Better then chipped pistons LOL when the smoke stops u add more oil that how u know ur low
  11. #11 Re: Compression test results
    Sep 2013
    Calgary, Alberta
    Quote Originally Posted by Nickell View Post
    compression sure jump up alot for the wet tests. Leakdown test will give you the answers you need.
    2004 comp g
  12. #12 Re: Compression test results
    ... osiris94ej's Avatar
    Sep 2012
    Casper Wyoming
    Honda and the DOHC head design on the vtec models if not maintained with proper valve lash adjustments they will burn valves. If the previous owner was out beating on it and lost the timing belt = valve train to piston damage. All of the honda vtec models are interference design. But as said it is normal to a point for these to burn oil, The valve guides, valve seals leak after time due to higher revs.
  13. #13 Re: Compression test results
    Dec 2008
    Cedar Rapids, IA
    i was thinking it was a burnt valve, im in process of ripping the head off
  14. #14 Re: Compression test results
    Dec 2008
    Cedar Rapids, IA
    heres a picture of the head and piston tops after head removal, any imput?
  15. #15 Re: Compression test results
    Sep 2013
    Calgary, Alberta
    turn the head over, fill the back of the valves will fluid. let it sit for 4hours or even overnight. if any seeps past the valve and valve seat there is your leak. exhaust valves are typically the ones that burn.
    if oil was leaking into the combustion cambers being sucked through the valve stem guides the spark plugs electrodes will have a build up....what did the plugs look like?
    2004 comp g
  16. #16 Re: Compression test results
    Dec 2008
    Cedar Rapids, IA
    they had build up for sure
  1. Compression test results?
    By Jcinstalls in forum 3.1L V6 (LHO/LG8)
    Last Post: 04-05-2015, 10:58 AM
  2. Torque App Sensor Test Results
    By Thompsju in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 11-13-2013, 02:07 PM
  3. Compression test procedure?
    By Elite6 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 08-08-2013, 09:42 PM
  4. Did a compression test today...
    By Iron Indian in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 10-03-2009, 09:37 AM
  5. Compression Test
    By RedGrandPrix in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 07-28-2009, 10:38 PM
