Thread: Heater issue
Results 1 to 6 of 6
  1. #1 Heater issue
    Feb 2010
    TN
    The heat comes out of the dash vents all the time even when I set it for floor and nothing comes out the floor, any ideas?
  2. #2 Re: Heater issue
    Feb 2013
    37.295091, -121.930053
    Blender door not working or your heater is bypassed
    im a cookie again yay me
    please learn to forum better.
    ^^new favorite quote
  3. #3 Re: Heater issue
    Jun 2011
    Texas
    The blend door is another name for the temp door. The mode door is the one that controls where the air comes out. When you move the mode control knob does it switch to any other position, or just not floor? Did you check the knob itself? Pull the knob off and see if it is cracked causing it not to move the actual switch.
  4. #4 Re: Heater issue
    Feb 2010
    TN
    Yeah checked the knob, does not work in and other position, heater can't be bypassed I am orginal owner and it worked fine up until about 1 month ago, BTW its a 1997 Grand prix GT N/A with the standard heat not the dual or digital. I thought it may be blend door, but was not sure since it is not dual zone. So how do I find and fix this thing?
    Thanks
  5. #5 Re: Heater issue
    Jun 2011
    Texas
    Grab the knob firmly and pull it straight off, turn it upside down and look at the side that connected to the switch. If it is cracked replace it. In the mean time you can get a pair of pliers and move the shaft of the switch without the knob on it
  6. #6 Re: Heater issue
    Feb 2010
    TN
    Knob is fine, I don't get defroster or floor just dash vents anyone got a writeup on blend door
  1. heater issue
    By nicks98gtp in forum General Tech Discussion
    Last Post: 01-02-2013, 01:25 AM
  2. Heater issue, please help
    By fuzzy54 in forum General Tech Discussion
    Last Post: 10-19-2012, 10:24 PM
  3. Heater issue
    By medicmandan in forum General Tech Discussion
    Last Post: 03-07-2012, 06:24 AM
  4. 97 heater issue
    By wib in forum General Grand Prix Discussion
    Last Post: 01-25-2012, 04:51 PM
  5. Heater fan in 97 GTP issue.
    By greenfiero1986 in forum General Tech Discussion
    Last Post: 10-16-2011, 02:51 PM
