Thread: Heater issue, please help
Results 1 to 2 of 2
  1. #1 Heater issue, please help
    Oct 2012
    MI
    I bought a 2007 Grand Prix back in July
    and never tested the heater because it was hot out. Now that it is
    getting cold I have noticed some strange behavior. At first I thought
    that I was not getting anything but luke warm heat and thought that I
    must have a stuck T stat but in looking at the issue closer I found
    out that the defrost is luke warm but the heat vents (middle vents)
    are rather warm sometimes and other times they seem luke warm.
    In
    testing this out I put a temp gauge on the heat vents and they were
    around 125, switched to defrost and it was only 95. I am kind of
    stuck as to what the issue is but I am new to GPs so I do not know
    all of the in's and outs and this seems to be a pretty complex
    system. The water pump was replaced a few months before I bought the
    car so I figured that they did not bleed the system but we tried that
    and it did not seem to do anything.
    Whats the next step?
    1)
    Replace T stat
    2) flush the system including heater core
    3)
    replace the blend door actuator
    Also I did recently replace
    the battery and I do not know if this issue existed before that or
    not, could that have caused this issue.
    Thanks
  2. #2 Re: Heater issue, please help
    Personally if it was me, I would flush the heater core and put in a new stock 195 thermostat and bleed the cooling system.
    Then if the problem was still there, look into the a possible blend door issue.
  1. Heater issue
    By medicmandan in forum General Tech Discussion
    Last Post: 03-07-2012, 06:24 AM
  2. 97 heater issue
    By wib in forum General Grand Prix Discussion
    Last Post: 01-25-2012, 04:51 PM
  3. Heater fan in 97 GTP issue.
    By greenfiero1986 in forum General Tech Discussion
    Last Post: 10-16-2011, 02:51 PM
  4. 97 GTP issue w inside Fan/Blower issue
    By JoeRappa in forum General Tech Discussion
    Last Post: 10-03-2011, 10:16 PM
  5. Heater messed up (switches KPH so MPH) DIC won't turn on of heater.
    By Colossus in forum General Tech Discussion
    Last Post: 03-06-2011, 01:13 AM
