Thread: heater issue
Results 1 to 2 of 2
  1. #1 heater issue
    GT Level Member nicks98gtp's Avatar
    michigan
    hey guys, its been a while since ive been on but the girl i started seeing drives a 2001 gp gt. Doesnt have the digital climate control, its got the one with a knob for speed, and level select, and the dual temp control with the two sliders. I noticed today that the heat and air both blow fine, and get hot, but when the level select is on max, vent, or bi level no heat (very very little) comes out of the dash vents. If you leave it on the same setings and switch the temp controls to cool it blows fine out the dash vents. The heat blows hot, blower motor works on all settings, and when the level selector is put on floor, or defrost it blows out heat as it should. Any ideas as to why the dash vents wont blow only when its set to hot? Any help would be appreciated thanks guys
    98 Gtp, ported s/c, fully rebuilt motor .20 oversized pistons, rebuilt trans, zzp pcm,more mods to come
  2. #2 Re: heater issue
    GT Level Member Erik Adam Rodriguez's Avatar
    Sep 2012
    bridgeport,NY
    mice had it happen before whats bad is when one dies in there and stinks up the car
    02 grand prix gt- L67 swap, ZZP 1.0 pcm, thrasher CAI, SLP 2.5 catback, A/C delete, 02 emulator, poly dog bone mounts, 6000k projectors with CCFL halos, 12 in slotted front rotors, ported blower and intake, evap and EGR deleted, 12" kicker cvr with 1000 watt amp, alpine cda 9886 deck
  1. Heater blower issue
    By kjohnson in forum General Tech Discussion
    Last Post: 10-30-2012, 10:21 PM
  2. Heater issue, please help
    By fuzzy54 in forum General Tech Discussion
    Last Post: 10-19-2012, 10:24 PM
  3. Heater issue
    By medicmandan in forum General Tech Discussion
    Last Post: 03-07-2012, 06:24 AM
  4. 97 heater issue
    By wib in forum General Grand Prix Discussion
    Last Post: 01-25-2012, 04:51 PM
  5. Heater fan in 97 GTP issue.
    By greenfiero1986 in forum General Tech Discussion
    Last Post: 10-16-2011, 02:51 PM
