Thread: Heater issue
Results 1 to 7 of 7
Threaded View
medicmandan Heater issue 02-25-2012, 03:34 PM
Fivefingerdeathpunch Re: Heater issue 02-25-2012, 05:40 PM
medicmandan Re: Heater issue 02-25-2012, 05:41 PM
medicmandan Re: Heater issue 02-25-2012, 06:19 PM
doug g Re: Heater issue 03-06-2012, 03:45 PM
Iceman6669 Had same problem with my 97... 03-06-2012, 03:55 PM
Freimuth Re: Heater issue 03-07-2012, 06:24 AM
  1. #1 Heater issue
    Utah
    A few months ago it stopped moving between defrost, vent and floor and got stuck somewhere in the middle with air coming out all three. Yesterday it stopped coming out everywhere except a little out of the vents. Blower is working fine. I crawled around under the dash but didn't come across anything loose or disconnected.
    Where do I start to diagnose this?
    2001 Pontiac Grand Prix SE 3100 with dual climate control.
    Update: Chased a vacuum line based on something else I read. Found one that comes down over the passenger side strut and behind the battery that was broken. Started following it with my hand and it just shattered.
    Anyone have a vacuum diagram? I'm guessing this jumps into the wiring harness behind the battery and through the fire wall. It's broken far enough down I probably need to replace all the way through the harness. There's one that comes through the firerwall on the passenger side and then up to the side of the heater. Is it the same one?
  1. 97 heater issue
    By wib in forum General Grand Prix Discussion
    Last Post: 01-25-2012, 04:51 PM
  2. Heater fan in 97 GTP issue.
    By greenfiero1986 in forum General Tech Discussion
    Last Post: 10-16-2011, 02:51 PM
  3. 97 GTP issue w inside Fan/Blower issue
    By JoeRappa in forum General Tech Discussion
    Last Post: 10-03-2011, 10:16 PM
  4. Heater messed up (switches KPH so MPH) DIC won't turn on of heater.
    By Colossus in forum General Tech Discussion
    Last Post: 03-06-2011, 01:13 AM
  5. a/c and heater
    By mcsddd in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 03-10-2010, 03:22 PM
