Thread: Thinking of converting to E85.. Yes or Ne??
Page 10 of 11 FirstFirst ... 891011 LastLast
Results 181 to 200 of 224
  1. #1 Re: Thinking of converting to E85.. Yes or Ne??
    Ya, but does'nt the torque management only kick in under certain conditions? Don't have my tuner in front of me but is there not situations where torque management is activated and when it is not activated? Not arguing one way or the other but if Chris' torque management isn't being triggered then that scan is irrelevant to your point.
  2. #2 Re: Thinking of converting to E85.. Yes or Ne??
    Feb 2009
    flintnasty MI
    torque management kicks in during shifting, the rate of torque reduction is adjusted via estimated torque vs desired torque (generally speaking).
  3. #3 Re: Thinking of converting to E85.. Yes or Ne??
    Banned
    CT
    Torque management never shows up as KR... EVER! This has gotta be one of the most asinine claims I've ever heard.
    Also, if false knock isn't real why do I get 176,000 results when I search "false knock retard" on google?
    http://lmgtfy.com/?q=%22false+knock+retard%22
    Why do vendors sell false knock elimination kits?
    Why do so many topics come up on this very forum about a sway bar hitting the downpipe and causing false KR?
    Seems like an awful lot of discussion on something that doesn't even exist.
    Are we done yet?
  4. #4 Re: Thinking of converting to E85.. Yes or Ne??
    Quote Originally Posted by SnowFlake View Post
    Are we done yet?
    Apparently google has 23,300,000 hit for san squash
    Apparently google has and 85,800,000 hits for aliens
    So no god damn it were not done............
    Believe what you will but by your thinking san squash and aliens must be real too????
  5. #5 Re: Thinking of converting to E85.. Yes or Ne??
    gardner,mass
    Quote Originally Posted by 98GrandPrixIraqVet View Post
    Aliens are real....
    RPF1 17x9 255/45 Direzza Zll
    04 COMPG- Vs, getrag 284 RIP
  6. #6 Re: Thinking of converting to E85.. Yes or Ne??
    Ohio
    Are we done yet
    False knock is REAL KNOCk, no such thing as false. If the sensor picks up noise in the system, then it is knock. Whether it be mechanical or internal. Something is wrong and it needs fixed.
  7. #7 Re: Thinking of converting to E85.. Yes or Ne??
    Banned
    CT
    Quote Originally Posted by MoarkatsINmuhtrailer View Post
    Wrong... pre-ignition or detonation is 'knock'.
    A sway bar hitting the downpipe and causing the sensor to trigger 'KR' is not knock. It's false knock.
    Are we really doing this right now?
    This is like the twilight zone.
  8. #8 Re: Thinking of converting to E85.. Yes or Ne??
    Ohio
    The sensor picks it up and tells the pcm to back the **** up...So yes, it is real knock. There is a problem, in this case, the downpipe and swaybar hitting eachother. Fix that, the knock goes away.
  9. #9 Re: Thinking of converting to E85.. Yes or Ne??
    Do you mean Knock Retard or actual Knocking occuring in the engine?
    The KR is always real because Knock retard is the retarding of the timing that is occurring due to the PCM picking up what it believes is knock from the knock sensors. It doesn't matter what is causing it to pull the timing. If the PCM is pulling timing and reporting KR, the KR is real.
    The cause for the KR can be false, as in the knock signal can be falsified.
    Unless you guys have a different defintion of KR from say the GM service manual or the HPT manual.
  10. #10 Re: Thinking of converting to E85.. Yes or Ne??
    So youre saying if abuse mode is triggered and spark is reduced, its just that. The spark is reduced and it will not show up as KR but just simply reduce to that value set in the abuse table?
  11. #11 Re: Thinking of converting to E85.. Yes or Ne??
    Banned
    CT
    Quote Originally Posted by gtpsleeper View Post
    Torque management is not knock and therefor does not trigger KR.
  12. #12 Re: Thinking of converting to E85.. Yes or Ne??
    It may not technically be KNOCK retard... I guess you could call it ABUSE retard...
    I guess my question is if you are commanding say 18*, the torque management kicks in, bringing it down to whatever value is in the settings (lets say 15*), then what would that be called?
    I guess since the pcm is now commanding this timing, it technically is not KR. But, it is still retarding from what you want to command...
    right?
  13. #13 Re: Thinking of converting to E85.. Yes or Ne??
    Banned
    CT
    Torque management, can, at times, retard spark timing.
    This does not show as KR. KR is only the PCM reacting to knock... whether it be real or false.
  14. #14 Re: Thinking of converting to E85.. Yes or Ne??
    conspiracy theories I see them everywhere............
    Apparently google also has a sh1t ton of misinformed people too but that couldn't be true, no not on the internet.........
    I say if it doesn't fvcking blow up call it a unicorn for all I care!!
  15. #15 Re: Thinking of converting to E85.. Yes or Ne??
    GTP Level Member danomite02's Avatar
    Jul 2011
    CT
    san squash??? wtf. guesss i better get ta googlin
  16. #16 Re: Thinking of converting to E85.. Yes or Ne??
    Jun 2011
    Try adding some blinker fluid.
  17. #17 Re: Thinking of converting to E85.. Yes or Ne??
    ^^^ 144,000 just sayin but its gotta be real
    OMGTVS whaaaaaaaaat?
  18. #18 Re: Thinking of converting to E85.. Yes or Ne??
    GTX Level Member crbquist's Avatar
    Massachusetts
    Boring
    01 Silvermist GTP - E85 - Cam - Heads - Phenolic IC - Polished Gen V - Stock trans...
  19. #19 Re: Thinking of converting to E85.. Yes or Ne??
    this thread needs more pig newton
    http://www.youtube.com/watch?v=n1mh2NclBac
  20. #20 Re: Thinking of converting to E85.. Yes or Ne??
    GTP Level Member tms8582's Avatar
    Washington Michigan
    Anyway Chris, now that you have the fuel pump fixed and a tune do you notice a difference in power with e85? I filled up the other day at $2.69 a gallon with a smile on my face
    Stage 1 Comp Cam / 105 Springs / Yella Terra 1.7's / SLP Headers / Ported heads / 255 Walbro fuel pump / Siemans 60# Injectors / 2.8 Pulley / 180 stat, 104 AL's / Intense e85 tune / 3" ZZP exhaust / GXP seats / KYB Coilovers /
  1. converting
    By cmn36 in forum General Tech Discussion
    Last Post: 01-15-2011, 07:18 PM
  2. converting a 01 to an 04
    By sasquatch094 in forum General Tech Discussion
    Last Post: 03-25-2010, 05:22 PM
  3. Converting to supercharged
    By Bechtel88 in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 03-23-2010, 09:31 AM
  4. question on converting.
    By gt42lst in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 10-12-2009, 11:54 AM
  5. Converting from a 1 bar to a 2 bar map.
    By TurboKent in forum General Tech Discussion
    Last Post: 03-16-2008, 02:10 PM
