Thread: Recall done and now wtf...
Page 2 of 2 FirstFirst 12
Results 21 to 26 of 26
  1. #21 Re: Recall done and now wtf...
    Barksdale AFB, LA
    It only affects supercharged 3.8L engines.
    Doing intake gaskets on the 3.4L/3.1L engines isn't hard from what I hear. Yes, you should use a torque wrench and make sure values are correct. The UIM has been known to crack on them if tightened too hard or in the wrong order.
    2009 Subaru Impreza WRX STI
  2. #22 Re: Recall done and now wtf...
    Feb 2008
    Quote Originally Posted by chevydaddy View Post
    hey need to but in what recall? i have a 00 grand pre 3.1 told to day i need to do intake gasket i have not hread any thing about this but seems really bad problem with these cars. can i do it my self ? know my way around the tool box. what about major adjusting was told most of it is torque spec and pretty stright forword off then back on. stores pic let me know need to do it soon
    This recall is for the front valve cover gasket on the L67 (3.8L S/C). You have a LHO (3.1L). Sorry to hear about your intake gasket, but just like us with the 3800s your intake gaskets is plastic, and it cracks (terrible design the geniuses at GM thought of). As referred to before make sure to pay careful attention to the torque specs on your bolts. Get a intake gasket set, that is the easiest way to get every gasket you need to do this job.
    Good luck!!!
  3. #23 Re: Recall done and now wtf...
    Oct 2008
    Bardstown KY
    thanks anyway and i sen the whole set like you say so ill be looking forword to it soon
  4. #24 Re: Recall done and now wtf...
    SE Level Member the1euge's Avatar
    Apr 2008
    Pittsburgh, Pa
    well so far everyone that i've talked to says its just condensation escaping through the exhaust. Makes me feel stupid getting worked up over it - just seemed like an awful lot of "condensation" for a lot longer than i remember. the "smoke" dissapates quickly out of the pipes, it just seems to persist for a lot longer than i remember. aka 20 minutes of idle or a 15 mile trip from school back to home and i still see it.
    anyways thanks for the help guys.. ill be sure to be keeping an eye on my oil and coolant levels (they both look perfect in color and havent moved @ all so far)
    losing sleep over vehicles sucks
  5. #25 Re: Recall done and now wtf...
    Feb 2008
    I know your talking about this in another thread too, but what is the outside temps were you are at the times you see the "white smoke"?
  6. #26 Re: Recall done and now wtf...
    Apr 2008
    Pittsburgh, Pa
    Quote Originally Posted by Blown97 View Post
    ya i think i jumped the gun and said it was due to condensation but after thinking about it today and getting time to actually look at it, i determined (thus the new thread) that it just wasnt the case. it is a bit cold outside, however i've had it idling for 20 minutes and it didnt dissipate like normal condensation would have done.
    anyways i will keep you posted because i have now ordered everything for a LIM change as i've set my mind up to that being the problem <crossing my fingers>
  1. Recall
    By crshoveride in forum General Tech Discussion
    Last Post: 08-01-2008, 01:46 PM
  2. My GTP is getting the recall done
    By hunter_alexander in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 06-21-2008, 11:41 AM
  3. ? on recall
    By mlambert in forum Off Topic Discussion
    Last Post: 06-20-2008, 02:58 PM
  4. Recall Letter
    Last Post: 05-01-2008, 09:57 PM
  5. Recall
    By GTPluv in forum Off Topic Discussion
    Last Post: 04-04-2008, 11:10 AM
