Thread: is my thermostat not opening?
Results 1 to 8 of 8
  1. #1 is my thermostat not opening?
    chicago
    i was going to work today and pull over white castle drive through to get some burgers. i was sit idling waiting for my food and notice the coolant temp was up at the middle mark which is pretty high. ok let me explain on my stock coolant gauge before i get you confuse. i don't know how to read this damn line on the gauge, but anyway the lines start 1/4, 1/2, 3/4. between 1/4 and 1/2 mark would be around 180* which is where the needle suppose to be on. i was sit idling no more than 5 minutes and the needle was moving little pass the 1/2 mark. the temp outside was 53* today. during the summer time the gauge never gone up to the 1/2 mark before. i turn on the heater and it seem to drop down little bit, but still little high. when i got to work the needle was up close to the 1/2 mark. does this sound like the thermostat is not opening properly? should i go ahead and change the 'tstat.
  2. #2 Re: is my thermostat not opening?
    Dekalb IL
    i had a similar problem it ended up that my overflow tank cap was cracked causing air pockets in my radiator which caused it to go to about the same temp
  3. #3 Re: is my thermostat not opening?
    chicago
    now that you brought up about the overflow tank that might be the problem. the overflow tank hose or around there on mine is leaking too. i think when i put the stainless steel sleeve on the hose i over tight the clamp and it must cracked the beak on the tank where the hose go in. either that or the hose itself must leak cause when i put my finger under it i get coolant on my hand.
  4. #4 Re: is my thermostat not opening?
    PA
    Like you said, you have no idea how hot the car actually is because the temp gauge on the dash is both highly inaccurate and hard to read. Best bet is to have the car scanned to determine what temp the car is really at. My gauge is so slow to move compared to the actual reading by the PCM, it's crazy.
    2001 GSE
  5. #5 Re: is my thermostat not opening?
    I live here. UR LOSN's Avatar
    Rockford, IL
    normally when a Tstat sticks.... the temp rises...and rises. and when it finally does open you will see the temp gauge go WAY down.
    if ti does not open... you would be able to hear te coolant boil out and go into the over flow tank...and that would be pretty loud. I have had a few stick in my day. also the smell of coolant everywhere gives it away.
    check the caps first!
  6. #6 Re: is my thermostat not opening?
    Apr 2008
    Chillin at the Beach , VA
    Check and see if your fans are cutting on also.
  7. #7 Re: is my thermostat not opening?
    GXP Level Member offroadfury6's Avatar
    Aug 2008
    Fayetteville, NC
    my GP ... ALWAYS stays at the 1/2 mark! nothing ever higher though.
    2011 Honda Civic EX-L - Leather/Sunroof/LOADED!
    2009 Saturn Aura XE - I got shift paddles!!!
    '98 Olds Cutlass - Good, Dependable
    '06 GP GT S/C - Traded it in
  8. #8 Re: is my thermostat not opening?
    chicago
    i think i found the problem. i change the overflow tank hose and refill coolant. i used 1.5 gallon. i don't know how i lost that much coolant. drove around town for about an hour and the temp gauge stay on the 1/4 line which is about normal where it's suppose to be. thanks guys for the input!
  1. Thermostat
    By keenan00gtp in forum General Tech Discussion
    Last Post: 10-20-2008, 05:46 PM
  2. 180 thermostat
    By LMCOOK87 in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 06-14-2008, 03:00 AM
  3. What Thermostat Should I Get ?
    By stlmo_gtp in forum Off Topic Discussion
    Last Post: 03-10-2008, 07:00 AM
  4. Transmission Fluid Thermostat
    By Zef_66 in forum 1997-2007 4 speed Automatic (4T65E) (4T65E-HD)
    Last Post: 02-14-2008, 08:49 AM
  5. Cloverfield opening tomorow.
    By Reptile in forum Off Topic Discussion
    Last Post: 01-21-2008, 08:17 AM
