Floor was a little wet before 11am due to a little bit of rain so when 11 hit (it was my lunch break) i decided to get under the glove box and discovered this little leak...
Then i decided to get under the cowl and seen this sitting water which i thought never got wet in the first place but there was way more water around the blower when i looked under the cowl around 11am but forgot to take a pic...
And after getting the part from my GM dealer, after about an hour later, i finally got it installed.
Now it took so long because i have a 1 piece cowl and it took for ever to cut off that piece that has the clips that holds the rubber wall between the drain and blower. I couldnt remove the wiper arms, had troubles with that so it was a tight fit installing the part.
By the way, where does that drain lead to? I wanna make sure its not clogged at all because i had leaves and other gunk next to it.![]()
