pull the carpet up, and run a garden hose down your windshield, while doing that watch for water to come streaming down the foot board to the floor. if so you need a new cowl deflector thing.
I just dont think water is getting in there though.
Quote Originally Posted by KZOO3800 View Post
What you need is a GM part called a deflector. Have a dealerdhip order you one. Water is leaking through the rotted rubber seal between your windshield and engine compartment. In this case the old-design deflector doesnt direct water to the drain over your wheel well.
Instead the water is draining into the blower motor area and then onto your floor. This is a common problem, exactly the same thing happened to me. Installing the deflector is easy and its cheap. Hit me up once you get one I can give you more instsllation info.
Wow kzoo? Your the closes to me that ive seen on here lol. What kind of grand prix you got?
Anways, i dont think its that though. As i said above, theres nothing wet when i check the blower motor and its still a bit dusty, no moisture or anything so it cant be that.
It has been rainy here all day also. After i cleaned up, it was still raining and i didnt see any water leaking through hours later.
