Thread: Flooded with Salt water
Results 1 to 13 of 13
  1. #1 Flooded with Salt water
    Apr 2008
    Hampton, VA
    I have a 2002 gtp that was in water for two extra high tide cycles.Only my floor boards are wet so I though I'd be find but after i started it she don't run very good. At about 4 grand it stalls like it was hitting the rev limiter or something. Also it smokes really bad now. So I'm thinking the water must have got in the motor. My insurance adjuster is coming out next week to tell me the damage. Oh yea my electric and heated seat doen't work anymore. What do you pros think. is it don or what??????
  2. #2 Re: Flooded with Salt water
    Wausau, WI
    if it was submerged in salt water, there is going to be corrosion anywhere that metal was exposed to it, the factory connections are supposed to be sealed, but with extended time period to corrosion, it could happen anytime, anywhere. Anytime an engine is submerged that is no good. depending on how far submerged you could have water in any of your holding tanks(coolant, motor oil, transmission, power steering, brakes, etc.) you could have short or long term damage to any or all of these areas, not to mention wiring. Personally, if I were you I would hope that they total the car and give you cash to get a new one. You could be fine, or this could be the start of your problems... I would start by making sure everything is dried out real good, changing all of your fluids out, new spark plugs and wires and hope for the best if you are going to keep it.
  3. #3 Re: Flooded with Salt water
    PA
    Having a car flooded is bad. Having a car flooded with salt water is 10X worse. Like mentioned above, the problems you see now are only the start of what I can imagine is going to be a nightmare for you. Before you started the car, I would have suggested to change the oil on the spot. Water in your oil is not good. Also make sure the change the air filter as that can get wet and cause issues with running. Would also be a good idea to change spark plugs and wires and check for more corrosion on the coil packs. And before you drive it too far, I would suggest having the entire transmission flushed with brand new fluid to get rid of any water that made it in there. One small drop of water in the oil or tranny fluid is enough to cause thousands of dollars of damage. So don't drive it too much without going over the whole car.
    That is just with the running gear. As mentioned, water could have gotten anywhere. While it can't do as much immediate damage, things like brake lines/cylinder/master cylinder, PS pump/rack, tie rod ends, ball joints, fuel tank, fuel lines, radiator/antifreeze, etc, etc can all get water in them and eventually cause the parts to fail prematurely. Not to meniton all the electrical connections can get water in them and cause really weird issues. And again, the salt water is 10x times worse because of the corrosion it will cause with your electrical system.
    Also, you have to try and dry the car out. If you don't, it can start to grow mold and smell from the water in the carpet/seats/insulation/dash, etc.
    So yeah, just hope that the adjuster totals the car and you can get out from the nightmares that are sure to happen.
    2001 GSE
  4. #4 Re: Flooded with Salt water
    Apr 2008
    Hampton, VA
    Well insurance company Totaled it. (R.I.P Pontiac GTP)
  5. #5 Re: Flooded with Salt water
    Donating Users ninnyGTP's Avatar
    Nov 2008
    Moreno Valley, California
    Consider yourself lucky. Getting any money from it? If so, buy a new one. GTP's are cheap as hell nowadays
    98 Grand Prix GTP L32, GenV, n*, 3.2", 1.9 rr's, 3.29 gears. All that jazz SOLD
    99 Mustang GT Steeda UDPs, 3.73s, Pypes O/R xpipe, Accufab plenum, Steeda CAI, B&M ripper, MHS s2 cams, 10.5:1 compression (290whp/310wtq) SOLD
    01 SVT Cobra #3654, B&M Ripper, K&N FIPK2, MAC O/R xpipe
  6. #6 Re: Flooded with Salt water
    Wooster, Ohio
    If they wouldn't have totaled it i would have been worried. That thing would be plagued with problems for the rest of its (very short) life. Find another one, preferably dry lol
  7. #7 Re: Flooded with Salt water
    Apr 2008
    Hampton, VA
    Don't know yet what I'll get but have my eye on a 05-06-ish GTO
  8. #8 Re: Flooded with Salt water
    Nov 2008
    GTO's are ghey. Get a T/A or G8 haha
  9. #9 Re: Flooded with Salt water
    Oct 2008
    Northern Illinois
    GTOs aren't bad, but I'd rather have a t/a.
  10. #10 Re: Flooded with Salt water
    Nov 2008
    Drove one.. They are indeed ghey haha
  11. #11 Re: Flooded with Salt water
    utah
    Quote Originally Posted by ninnyGTP View Post
    x2 v8 grand ams......only that would be cooler
  12. #12 Re: Flooded with Salt water
    Wooster, Ohio
    G8 gt!!!!
  13. #13 Re: Flooded with Salt water
    Apr 2008
    Hampton, VA
    Well I ended up with a 2007 Silverado 1500 LS.
  1. What to do about the really caked on road grime and road salt?
    By s1795so2 in forum Detailing Tips and Tricks
    Last Post: 12-09-2010, 06:55 PM
  2. Water, water, everywhere!
    By TheDesertFox in forum General Tech Discussion
    Last Post: 06-20-2009, 02:23 PM
  3. Water in Oil
    By JosephJ in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 05-26-2009, 06:03 AM
  4. will the salt from the roads ruin the finish on my headers?
    Last Post: 02-01-2009, 04:15 PM
  5. Flooded Basement
    By Deezul_AwT in forum The Rant Forum
    Last Post: 05-15-2008, 05:52 AM
