Thread: How in the H*L* do u remove the fog lights!?!
Results 1 to 19 of 19
  1. #1 How in the H*L* do u remove the fog lights!?!
    Donating Users Nickell's Avatar
    Dec 2008
    Cedar Rapids, IA
    somebody please inform me how to remove the stock fog lights on a 97-03 grand prix!
    1998 GP Daytona - PLOG, 104's, PRJ Wires, Lucas 42.5's, DHP 1.0 Tune, DP, Full Borla, GPO's, Roof Rails, Gen 2 Spoiler, 04+ Needles, Menards Intake, 3.5 Pulley, SSC Springs, Corn-fed
    2000 Bonneville SSEI - 212k+, New Gaskets and Stuffs
  2. #2 Re: How in the H*L* do u remove the fog lights!?!
    Jersey
    ok, first you take out the driver side headlight assembly, reach down pull out the plug, you will see 2 bolts, unbolt them and pull the assembly out straight and carefully, you don't want to bend the brackets (if brackets bend you will have one fun time getting them out). With the passenger side unfortunately you will have to repeat these steps but from the bottom of the car. When you tighten down the brackets for re-assembly do yourself a favor and don't over tighten the bolts or you will bend the brackets.
    16' wrx sti- stock
  3. #3 Re: How in the H*L* do u remove the fog lights!?!
    Dec 2008
    Cedar Rapids, IA
    well the thing is, im getting new fogs lol
  4. #4 Re: How in the H*L* do u remove the fog lights!?!
    Jersey
    yeah, i figured that but really you dont want to bend the brackets because the design is very shi*y its 2 holes and the 2 bracket studs have to go into these 2 holes exactly right, a little over tightening and you bend it. Thus leaving you a really hard time trying to get the brackets out later (if you have to change a bulb or whatever). When you take them out you will see what i mean. Ive bent the brackets before and its not fun...
    16' wrx sti- stock
  5. #5 Re: How in the H*L* do u remove the fog lights!?!
    Dec 2008
    Cedar Rapids, IA
    alright, thanks for the help
  6. #6 Re: How in the H*L* do u remove the fog lights!?!
    Jersey
    yep no problem
    16' wrx sti- stock
  7. #7 Re: How in the H*L* do u remove the fog lights!?!
    Jul 2008
    Poteau Oklahoma
    really? I just reached under my bumper and turned and pulled them out.
    98 chevy truck
    83 Olds cutlass
    86 Olds cutlass
    06 se gold
  8. #8 Re: How in the H*L* do u remove the fog lights!?!
    Jersey
    Quote Originally Posted by justwhisen View Post
    yeah that would be the case if he was just replacing the bulbs and with after-market fogs you will more than likely need to pull the entire assembly to replace the bulbs.
    16' wrx sti- stock
  9. #9 Re: How in the H*L* do u remove the fog lights!?!
    Jul 2008
    Poteau Oklahoma
    well I guess that would be the best way then.
    98 chevy truck
    83 Olds cutlass
    86 Olds cutlass
    06 se gold
  10. #10 Re: How in the H*L* do u remove the fog lights!?!
    GTP Level Member 1ATony's Avatar
    mass
    I'll add to the post for you guys incase anyone else doesn't know how to do this.
    Here's a great youtube video that will show you exactly how to remove your Pontiac Grand Prix fog lights, and the tools needed for the job.
    How To Install Replace Fog Light Grand Prix 97-03
  11. #11 Re: How in the H*L* do u remove the fog lights!?!
    Apr 2012
    Manorville, Ny
    Quote Originally Posted by 1ATony View Post
    Is there a video to show how to get to the wires for the fogs, I'm installing my hids that just came in the mail tomorrow and want to know the right way. I could just figure it out but, you know how that goes
    1998 Grand Prix Gtp 4 Door.
    Team Li SPL
  12. #12 Re: How in the H*L* do u remove the fog lights!?!
    Yay, zombies.
  13. #13 Re: How in the H*L* do u remove the fog lights!?!
    Ocala, FL
    Yay, zombies.
    New post looks like a decent addition for someone searching for a thread like this
  14. #14 Re: How in the H*L* do u remove the fog lights!?!
    Quote Originally Posted by codyAK View Post
    It is, I'm just post whoring since its like two years old.
  15. #15 Re: How in the H*L* do u remove the fog lights!?!
    mass
    lol, I noticed it was an old post figured I'd add to it for members that search for stuff.
    I have some great Grand Prix how to vids. Working on approval to join the site as a vendor so that we can help you guys out a little.
  16. #16 Re: How in the H*L* do u remove the fog lights!?!
    http://www.grandprixforums.net/how-r...hts-53120.html
    Thats how its supposed to be done.
  17. #17 Re: How in the H*L* do u remove the fog lights!?!
    Nov 2011
    Chicago
    So I got underneath my 2000 GP and tried unscrewing the 2-10mm bolts for the fog light brackets. I turn 4ever and nothing happens. I feel the heads of the bolts moving too as I try to take the nut off. Any suggestions? Thanks.
    Speedy
  18. #18 Re: How in the H*L* do u remove the fog lights!?!
    Waukesha, WI
    yay zombie threaddd.
    SPEEDY. your going to have to try and get a vise grips on the back side of the bolt. not easy or fun..
    i would suggest taking of the front cover and grinding the nuts off the brackets then welding new studs on.. its fun
    RayRay
    92 Turbo miata
    71 bagged lemans wagon
    02 lexus is300
  19. #19 Re: How in the H*L* do u remove the fog lights!?!
    Nov 2011
    Chicago
    RayRay, thanks for the response and the valuable info. I had figured out how to twist of the bulbs and replace them but will remember what to do next time if I have trouble, thanks.
    Speedy
  1. How to remove the supercharger ?
    By ryangtp89 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 10-31-2009, 04:20 PM
  2. Can't remove key
    By GrandPrixlbc in forum General Tech Discussion
    Last Post: 08-08-2008, 06:30 PM
  3. How Can I Remove This ?
    By stlmo_gtp in forum Visual/Body Modifications
    Last Post: 04-23-2008, 01:18 PM
  4. How to remove the ashtray?
    By IndeedSS in forum General Tech Discussion
    Last Post: 01-20-2008, 06:44 PM
