Thread: Questions after powerlog install.
Results 1 to 4 of 4
Bluemagic Questions after powerlog... 05-26-2012, 04:00 PM
Bogers04SS Re: Questions after powerlog... 05-26-2012, 04:49 PM
Bluemagic Ok great I'll try that 05-26-2012, 05:31 PM
Bluemagic Yup. That was the issue.... 05-27-2012, 09:05 PM
  1. #1 Questions after powerlog install.
    Dec 2010
    DMV
    Ok I installed a powerlog a few days ago and have noticed a few things.
    One my exhaust tone has changed dramatically. Is that normal?
    Seems more along the lines of a exhaust leak but can't find one.
    Also where the radiator hose is right under it is an exhaust pipe with with two screws. I noticed one isn't screwed all the way in. Like one is taller than the other. And it seems Like that's where it's louder at...I think I just figured out the answer lol. Any other thoughts are welcome
  2. #2 Re: Questions after powerlog install.
    GT Level Member Bogers04SS's Avatar
    Feb 2010
    Mocksville, N.C.
    No... its not normal to sound like that.....Sounds like the flange where the Powerlog and Crossover pipe meet is leaking. Hold your hand close, but not too close the the flange as the car is running, see if you can feel any air against your hand. If so, turn the car off, and retighten the crossover bolts. Turn one 3 turns then the other 3 turns... keep going till both bolts are tightened. This should solve your problem.
    04 Impala SS -- SOLD
    08 Prix GXP -- FWI, 3in DP, TR6IX plugs, Ported & polished throttle body, ported intake manifold, DiabLEW Tuned, wrapped crossover pipe, Cat delete, Factory res., Muffler delete, Poly motor mounts, shift kit, LED bulbs in just about every Da*n thing, ect..
    Dec 2010
    DMV
    Dec 2010
    DMV
    Yup. That was the issue. Thanks
  1. Remote Start Install Questions
    By 1detroitryder in forum Audio, Security & Visual Electronics
    Last Post: 12-22-2011, 08:24 AM
  2. Intercooler install questions
    By shawn3091 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 04-21-2011, 09:50 AM
  3. questions regarding aftermarket install
    By bkatrenak in forum Audio, Security & Visual Electronics
    Last Post: 03-11-2011, 07:22 AM
  4. intercooler install questions
    By screamingreenmonster in forum General Tech Discussion
    Last Post: 05-17-2010, 05:17 PM
  5. ZZP MPS Install questions
    By Liquifire in forum General Tech Discussion
    Last Post: 10-13-2009, 02:21 PM
