Thread: Benefits of ant EGR delete ?
Results 1 to 20 of 36
  1. #1 Benefits of ant EGR delete ?
    GTX Level Member stlmo_gtp's Avatar
    St. Louis
    does anyone know any benefit's that deleting the egr valve would give you ?
  2. #2 Re: Benefits of ant EGR delete ?
    SS-DD Level Member IndeedSS's Avatar
    St Louis MO
    Quote Originally Posted by stlmo_gtp View Post
    None other than if you had an IC it would prevent your core fins from getting blocked. I have a plate for my EGR so in a matter of minutes I can block it right at the valve itself. When I was IC'd mine was blocked off. After going back to non-intercooling, I've swapped it in and out a few times looking for any benefit one way or another. I couldn't find any, to tell the truth.
    The one thing I've noticed is that the s/c inlet gets a little deposit on it, However would it not be better to go into the intake and be burnt versus, potentially clogging the cat? I can't accurately guess as to the answer, but my feeling is yes.
    You live near me you'll want that on your car.
    04 Indy SS build #972 - Traded
    2010 Camaro SS LS3
  3. #3 Re: Benefits of ant EGR delete ?
    PA
    I have found that my car is easier to tune, and gives a much tighter tune. Thus making my car run a bit smoother. And the tighter tune increased my mileage about 1 mpg.
    EGR delete is best suited for IC cars. And a tuner is a must to retune the car correctly after it is removed, IMO anyway.
    2001 GSE
  4. #4 Re: Benefits of ant EGR delete ?
    Moore, Oklahoma
    Cleaner intake runners overall, I think its worth removing IMO. If anything, DEFINATLY remove it if your ICed. It costs hardly nothing to pull off...
    Shawn W. Larsen
  5. #5 Re: Benefits of ant EGR delete ?
    St Louis MO
    Quote Originally Posted by Iron Indian View Post
    I assume he lives in STL and as a result will likely find it helpful to at least make it look like it's functional.
    As far as intake runners, wouldn't the little amount of coating from the EGR smooth the rough texture and be the equivalent of low budget polishing?
    Seriously though, I would rather have less clean intake runners than a clogged cat.
    2010 Camaro SS LS3
  6. #6 Re: Benefits of ant EGR delete ?
    Oklahoma
    How many clogged cat's have you seen from EGR deletes?
  7. #7 Re: Benefits of ant EGR delete ?
    St Louis MO
    It's only a thought in print. When I took my blower apart last week I noticed the slight oily film around the EGR port. It occured to me that if I still had my EGR blocked where would that stuff go?
    2010 Camaro SS LS3
  8. #8 Re: Benefits of ant EGR delete ?
    St. Louis
    yea i am from St. Louis i'm not sure if i am going to go with a EGR delete especially since i just got robbed for some money today the problem that everyone told me was my CPS ened up being my Fuel Pump, I was wondering why i was getting 17mpg on the highway, talk about a gas hog so that sucked about $900 bucks outta my bank to have my trusted shop do it for me because i didn't have the time to do it. Does $900 sound like a rip for a Fuel Pump + Relay replacement ?
  9. #9 Re: Benefits of ant EGR delete ?
    Saraland Alabama
    depends on what pimp they used (delco one runs about $400 doesn't it?)
  10. #10 Re: Benefits of ant EGR delete ?
    St. Louis
    After so research the pump runs at about $334 and the relay runs at about $21 here are the item numbers just incase anybody needs them at some point and time:
    ACDELCO Fuel Pump item number #MU227
    ACDELCO Fuel Pump Relay item number #15-50448
  11. #11 Re: Benefits of ant EGR delete ?
    St Louis MO
    Well they don't have to drop the tank to put it in so I don't think the labor time would be that long. However we live in an area with the highest auto repair rates. Dealer 3 miles from my house charges $135 an hour. At those rates it doesn't take long for the money to get large on you.
    Oh and they will have to mark up the parts too.
    Looks like PRJ charges $210 for a Racetronix pump with wiring harness. This is supposed to be one of the best fuel pumps.
    2010 Camaro SS LS3
  12. #12 Re: Benefits of ant EGR delete ?
    St. Louis
    well they do know that i do have some mods done which i wouldn't complain if they did put something better in there but then i think to myslef what are the chances that they would do that for me ?
  13. #13 Re: Benefits of ant EGR delete ?
    Moore, Oklahoma
    Who runs a cat? I lost mine a long time ago.
    And deleting the EGR ain't going to kill the CAT (if you have one), thats a myth.
    Shawn W. Larsen
  14. #14 Re: Benefits of ant EGR delete ?
    Donating Users chico's Avatar
    Also it cleans up te engine bay a bit I put a plug in the LIM and the rear mnfld I cut off the tube on # 6 weldedup the primary then had it jet hot coated.
    04 gto stock,97 GPGT l-36 block diamond pistons ,l-32 rods ,custom comp cam grind,HS 1-7 RR, p&p heads, SS IC,SS M-90 3.5" ,4t60eHD,from Gonzales TX.
  15. #15 Re: Benefits of ant EGR delete ?
    St Louis MO
    How do you know this? No really? If it's a myth it's one I've never heard it before. I only mentioned it because it seems to makes sense that if the residue does make it to the intake then it has to go somewhere. Doesn't it?
    Oh and I run a cat because you will not pass inspection here without one.
    2010 Camaro SS LS3
  16. #16 Re: Benefits of ant EGR delete ?
    PA
    Quote Originally Posted by IndeedSS View Post
    Running without an EGR isn't going to kill your cat. Many cars run without an EGR and have a cat, straight from the factory. Also, your EGR isn't recirculating exhaust gases all the time. Only part of the time. And at WOT, it is disabled. When do you think you make the most potent exhaust gases, when you are running rich. When do you run rich? WOT. So when you are running the richest, making exhaust gases with the most deposits in it, the EGR is disabled. So if the EGR was needed to prevent the cat from clogging, wouldn't the be operative at WOT?
    Also, the CAT burns hot enough most of the time to burn out these deposits anyway. Running without and EGR isn't any harm to your cat, bottom line.
    2001 GSE
  17. #17 Re: Benefits of ant EGR delete ?
    Saraland Alabama
    what hurts the cat is idling
  18. #18 Re: Benefits of ant EGR delete ?
    Bastard Reptile's Avatar
    Kansas City, MO
    Quote Originally Posted by archemedes View Post
    I've never ever heard of this before.....please explain.
  19. #19 Re: Benefits of ant EGR delete ?
    St Louis MO
    Do we not know that running too rich shortens the life of the cat?
    2010 Camaro SS LS3
  20. #20 Re: Benefits of ant EGR delete ?
    Kansas City, MO
    I've heard of that....and certain fuel additives etc etc can destroy a converter....I've just never heard of idling doing this. Not saying it won't, I"m just curious.
  1. Do you see huge benefits in premium/hi-test/whatever you wanna call it.
    By Edmonchuck in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 02-03-2008, 08:11 PM
  2. what the heck does "FWI, PEM, AND EGR DELETE" MEAN?
    By BLACKEDOUTGTP in forum General Tech Discussion
    Last Post: 01-08-2008, 08:31 PM
  3. EGR Delete Benefits/Discussion
    By TyroElite in forum General Tech Discussion
    Last Post: 01-05-2008, 04:39 PM
