Thread: gtp exhaust leak??
Results 1 to 7 of 7
  1. #1 gtp exhaust leak??
    May 2012
    elmwood
    My 03 gtp is louder than hell lately, it sounds like its coming from the back manifold or where u bend is. Is this normal on 3.8's? Gona go through and check the bolts and pipes once the car cools down.
    2001 gtp, completely stock for now...
    1983 chevy heavy half ton, 350 small block built for madness!
  2. #2 Re: gtp exhaust leak??
    Jan 2012
    Philadelphia
    could be your resonator they go bad alot on these cars
  3. #3 Re: gtp exhaust leak??
    get your car up in the air, when its cold, start it get under it and feel for air blowing out of the pipe or res or muffler, start at the front, it heats up fast.
    if your car has the stock exhaust on it still you will need to get stuff re welded in or if you can weld it yourself, thats a plus.
    if its all clamped in and had been replaced its easy to replace whats rotted.
    i found it easier to just drop the whole cat back, remove it from the car to work on it, 2 bolts at the cat and the rest is just rubber hangers. the mufflers have 2 bolts to drop the bracket that holds the rubber hangers, i took them 2 bolts off, and the muffler dropped real easy. they are the only hangers that may give you a problem.
    plan on picking up a new cat to res gasket and 2 new bolts for it, they will break or strip out. truth be told its better if they just break, they never come off. i had to cut one off with a grinder as it stripped out the heads of the nut and bolt real easy. the other one snapped.
  4. #4 Re: gtp exhaust leak??
    May 2012
    elmwood
    I've been under the car once and it looks like the resonator has already been chopped out and another one welded in. I can weld it so that's no problem but how much would a new resonator cost or would it b better to just get a cat back exhaust system ?
  5. #5 Re: gtp exhaust leak??
    what you can do is get a glass pack muffler form auto zone or who ever, they run about 25 bucks. measure your old res buy one close to its size. if you still have a cat to res flange, you can weld on a flange and then weld the pipe on the other side.
    i got my flange from a muffler shop, the local stores dont have it here. and you need a 2.25 id glass pack.
    then cut one tube off and weld the flange on.
  6. #6 Re: gtp exhaust leak??
    May 2012
    elmwood
    I have a set of glass packs laying in the shed but I didn't know u could use them, gona look tomorrow but I think they're about the same size and already have the flanges
  7. #7 Re: gtp exhaust leak??
    if you google a walker resonator for your car, the glass pack looks the same. at a 1/4 the price. it will sound stock.
  1. 3.1 water coming from exhaust leak on exhaust manifold
    By ibhuff in forum 3.1L V6 (LHO/LG8)
    Last Post: 10-21-2011, 01:54 PM
  2. Is it safe to drive with an Header exhaust leak or any exhaust leak??
    By GOTIT4CHEAP16 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 01-11-2011, 05:45 PM
  3. Exhaust leak, need ideas
    By Dtrick22 in forum General Tech Discussion
    Last Post: 08-25-2010, 10:08 PM
  4. exhaust leak
    By grand2000prixgtp in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 09-13-2009, 10:31 AM
  5. Need help with an exhaust leak
    By thenervemann in forum General Tech Discussion
    Last Post: 04-26-2009, 09:28 PM
