Thread: Remote Start Install Questions
Results 1 to 5 of 5
  1. #1 Remote Start Install Questions
    Dec 2011
    Detroit
    Hello Everyone as you can see this is my first post... now that were past that i have a question.....
    I have a 2004 gt2 Grand Prix i'm currently know where near my home for about another 2 months and i have a Avital Remote start system and a Dei Bypass module ... I've done 1 or two remote start installs on other cars Easily this one puzzles me.... Of course the avital has a relay harness that has some pretty heavy gauge wires in it which is normal , however under the dash on my GP i see no heavy gauge wires ... just the 16 gauge wires so where do i connect this harness i have a pretty good diagram that has a couple pics most wires are on the bcm plugs... Where do i connect these wires ????? any help would be appreciated...
    AvitalĀ® 4103
  2. #2 Re: Remote Start Install Questions
    GT Level Member Brian99SE's Avatar
    Dec 2011
    Cadiz, Ky
    Source: Car Alarm, Car Stereo, Mobile Video, and Cruise Control Info for Installers
    DIRECTWIRE™ WIRING INFORMATION - PONTIAC / GRAND PRIX / 2004 / Remote Start
    [PRINT THIS PAGE]
    12volts red (50A), red (40A) + back of fuse box, passenger dash
    Starter yellow + ign harn or BCM, conn. C1, pin 21
    Notes: The BCM (Body Control Module) is below the driver side dash to the left of the steering column.
    Second Starter N/A
    Ignition pink + ign harn or BCM, conn. C1, pin 22
    There are two pink wires in the BCM plug that meter as ignition. To verify that the correct wire is being energized for remote start, slide the key in the ignition key cylinder and then activate remote start. If the key in ignition warning chime comes on, then the correct wire is being energized.
    Second Ignition N/A
    Third Ignition N/A
    Accessory brown + ign harn or BCM, conn. C1, pin 23
    Second Accessory N/A
    Keysense lt. green - ign harn or BCM, conn. C1, pin 40
    If the service security lights comes on during remote start or after key takeover, see DirectFax document 1502.
    Power Lock red/black - BCM, conn. C2, pin 2
    Power Unlock orange/black - BCM, conn. C2, pin 11
    Lock Motor gray 5wi BCM, conn. C2, pin 52
    Unlock Motor tan 5wi BCM, conn. C2, pin 46
    Parking Lights+ brown + front of fuse box, passenger dash
    Parking Lights- brown/white - BCM, 18 pin plug, pin 8
    Hazards tan - BCM, 18 pin plug, pin 16
    Turn Signal(L) use hazards wire
    Turn Signal(R) use hazards wire
    Reverse Light lt. green + BCM, conn. C2, pin 42
    Door Trigger see notes - BCM, conn. C2
    Notes: The driver door trigger is gray/black in pin 26, the front passenger door is black/white in pin 17, the left rear door is lt. blue/black in pin 7, and the right rear door is lt. green/black in pin 5. Use all four wires and diode isolate each.
    Dome Supervision gray/black + BCM, conn. C1, pin 43
    Trunk/Hatch Pin red/black - BCM, conn. C2, pin 3
    Hood Pin N/A
    Trunk/Hatch Release lt. blue + BCM, conn. C2, pin 45
    Power Sliding Door N/A
    Factory Alarm Arm lt. green - BCM, conn. C2, pin 22
    Factory Alarm Disarm purple - BCM, conn. C2, pin 24
    Disarm No Unlock see factory alarm disarm
    Tachometer white ac ignition control module, pin E
    Notes: The ignition control module is on top of the engine towards the passenger side.
    Wait to start N/A
    Brake Wire white + BCM, conn. C2, pin 30
    Parking Brake orange/black - BCM, conn. C2, pin 9
    Horn Trigger black - BCM, conn. C1, pin 4
    Memory Seat 1 N/A
    Memory Seat 2 N/A
    Memory Seat 3 N/A
    Interface Module: Category:
    Immobilizer Bypass Required:
    Yes Type:
    PASS-Key III
    Part #: 556UW
    Alternate Part1 #: DesignTech 20402
    Alternate Part2 #: DesignTech 29402
    99 Grand Prix SE-Blue CAI, 3.03 GR Transmission, U Bend Delete.
    time to call the exterminator
  3. #3 Re: Remote Start Install Questions
    Dec 2011
    Detroit
    Thanks i have that dia gram i even have on with pictures of each wire.However my question is my remote starter has a Relay harness of thicker gauge wire. the wires in the car are 16 gauge which is much smaller,am i to attach the heavy gauge wire to the smaller wires ?? or is there another place ..
    SE Level Member Compg4me's Avatar
    Dec 2011
    Grand rapids Mi
    You attach the heavy gauge wires to the correct smaller gauge wires if the ignition switch. The 12 volt power must be run to the back of the fuse box where there is a higher amp wire or run directly to the battery.
  5. #5 Re: Remote Start Install Questions
    Dec 2011
    Detroit
    Quote Originally Posted by Compg4me View Post
    Thank you very much i was curious because in previous cars all the wires werent so small thanks again
  1. A few questions about 2007 Remote Start
    By krpiper in forum Audio, Security & Visual Electronics
    Last Post: 02-24-2017, 11:45 AM
  2. Remote start questions
    By semocoachworks in forum General Tech Discussion
    Last Post: 01-14-2012, 03:33 PM
  3. how hard is it to install an alarm with remote start
    By nascartech in forum Audio, Security & Visual Electronics
    Last Post: 11-01-2010, 05:55 PM
  4. Need Help On Troubleshooting Bulldog Security Remote Start Install
    By eb97951 in forum General Tech Discussion
    Last Post: 12-24-2008, 07:39 AM
  5. Remote Start Install Questions...
    By Incomudrox in forum Audio, Security & Visual Electronics
    Last Post: 12-02-2008, 02:19 PM
