Thread: lower intake manifold might be leaking...
Page 4 of 6 FirstFirst ... 23456 LastLast
Results 61 to 80 of 103
  1. #61 Re: lower intake manifold might be leaking...
    Dorman 47065
  2. #62 Re: lower intake manifold might be leaking...
    GT Level Member andremike's Avatar
    Nov 2009
    chicago
    Dorman 47065
    I take it then you think the Dorman elbows are ok... Seems like some people on this board even complained about the dorman elbows..
  3. #63 Re: lower intake manifold might be leaking...
    i just used a doorman set on my 98, it works. cost 5 bucks too for both elbows.
  4. #64 Re: lower intake manifold might be leaking...
    Nov 2009
    chicago
    GREAT!! Thanks Guys. Here is what I will be buying for my 2000 GT, Naturally asperated..... I know I hav duplicate O rings for the injectors, but its not clear what the kit comes with.. upper or lower.. or both..
    ACDELCO Part # PF47 {#19210284, 19256042, 25010792} CLASSIC DESIGN W/THREADED BASE PLATE
    FILTER,OIL
    C
    $3.35 $3.35
    FEL-PRO Part # ES72833 Set D
    $6.34 $6.34
    FEL-PRO Part # VS50080R PermaDry®
    w/o Grommets; Services both covers; molded rubber gskts. incl.
    D
    $9.95 $9.95
    ACDELCO Part # 6K915 {#88932782} K06 13/16" x 92 1/8"
    BELT,SERPENTINE 4 DOORS; ACSRY DRIVE
    BELT,SERPENTINE 2 DOORS; ACSRY DRIVE
    B
    $33.79 $33.79
    DORMAN Part # 615180 {#89017272} Includes EGR Tube
    Includes All Gaskets and Seals as Required; Upper
    D
    $74.79 $74.79
    ACDELCO Part # CV892C {#25043843}
    VALVE,PCV
    C
    $4.73 $4.73
    FEL-PRO Part # ES71190 Set Of 4
    Lower set; Injectors to cylinder head
    D
    $3.46 $6.92
    FEL-PRO Part # ES71192 Set
    Upper set; Injectors to fuel rail
    D
    $3.35 $6.70
    DORMAN Part # 47065 Elbows with O-Ring Seals; Size; (1) 7/8" x 7/8" and (1) 7/8" x 1"; Material: Plastic
    Elbow; Plastic; w/O-ring Seal; Includes Upper & Lower Elbow
    + Sold in packs of 2; Price reflects cost of each individual item, not the pack
    A
    $1.16 $2.32
    FEL-PRO Part # MS98014T Intake Manifold Gasket Set PermaDryPlus®
    2nd Design; w/Rubber-plastic end seals w/Locating pins; Lower set only; Upper set not incl.; PermaDryPlus® int. manifold gskts. incl.
    D
    $50.79 $50.79
  5. #65 Re: lower intake manifold might be leaking...
    What year/model is this car?
  6. #66 Re: lower intake manifold might be leaking...
    Nov 2009
    chicago
    2000 grand prix GT, Naturally asperated
  7. #67 Re: lower intake manifold might be leaking...
    Nov 2009
    chicago
    I read something about replacing bolts... Are these the bolts that get replaced?
    FEL-PRO Part # ES74033
    do these come out during this job? I don't think so right?
  8. #68 Re: lower intake manifold might be leaking...
    Nov 2009
    chicago
    DONE!!! Parts ordered...
  9. #69 Re: lower intake manifold might be leaking...
    which bolts did you order? Where do they go?
  10. #70 Re: lower intake manifold might be leaking...
    Nov 2009
    chicago
    I didn't order the bolts.. I ordered everything in the list I posted. Those are for the cylinder heads or something... Why, Do I need them?
  11. #71 Re: lower intake manifold might be leaking...
    GTX Level Member bps02gtp's Avatar
    Nov 2010
    Illinois
    you dont need them. you wont be removing those bolts.
    the "upper" and "lower" orings on the injectors are the same size. when you pull the fuel rail, the injectors will still be attached only showing the "lower" orings. those are usually all you have to replace. if you want to be extra cautious like Bill mentioned then remove the injectors from the fuel rail and replace the "upper" orings. but you dont have to. the fuel rail is not hard to pull off and so you can replace them if they ever start to leak. thats up to you. thats what i personally would do because like i said its not hard. and i'm cheap so if i can save 5 bucks then i'll do it.
    all coolant elbows are cheap. theyre 5 bucks. if you're doing the job yourself these are going to break when you take them out.
    which btw, are you doing this or are you having that shop i told you about do it?
  12. #72 Re: lower intake manifold might be leaking...
    Nov 2009
    chicago
    That shop did give me a price, which wasn't bad, but my local mechanic was able to match it.. $400.00
    I was wondering if the elbows from the dealer were better...
  13. #73 Re: lower intake manifold might be leaking...
    Nov 2010
    Illinois
    just get the cheap ones
  14. #74 Re: lower intake manifold might be leaking...
    I've had both sitting here in front of me at the same time. Personally I've never been able to tell a difference.
  15. #75 Re: lower intake manifold might be leaking...
    Nov 2009
    chicago
    1 last question.... do you guys think I should of put a new water pump in? 12 years old and 78k miles....
  16. #76 Re: lower intake manifold might be leaking...
    yeah if your up to spending another 60 dollars lol.
    its good insurance if you ask me.
    you need thread sealant for the 4 long bolts, they go into the water jacket of the block and can leak if not resealed. not sure if the intake bolts on a N/A needs sealant, the s/c does.
  17. #77 Re: lower intake manifold might be leaking...
    Nov 2009
    chicago
    Well now 'd have to pay shipping again... how long do water pumps last? If I don't replace it now are they expensive to replace later? A lot of labor involved?
    I see 2 of them on rockato...
    Acdelco part# 252693 for $28.00
    And acdelco part # for 251718 for $89.00. Is this a heavy duty?
    Then they say they don't come with mounting bolts. What number is that?
  18. #78 Re: lower intake manifold might be leaking...
    i got one from my local parts store, like 60 bucks with a new gasket included.
    1 st tip, break the 4 WP pulley bolts loose first, before you take the belt off, you need to unbolt the power steering pump and move it to the side to get to one bolt on the WP, and the lower idler pulley for the s/c by the crank also needs to come off so you can get to a bolt as well. its t50 torx socket. make sure you cleaned off all the old gasket material from the timing cover, use a razor if need be to scrape it clean, the 4 long bolts of the wp need thread sealant on the or they can leak coolant.
  19. #79 Re: lower intake manifold might be leaking...
    Nov 2010
    Illinois
    you dont need to seal the LIM bolts on a s/c engine
  20. #80 Re: lower intake manifold might be leaking...
    Nov 2009
    chicago
    So since I have a mechanic do this stuff... is it expensive to replace typicaly. How much labor is involved? Do I need new bolts? And what are the part numbers? My mechanic should know about the sealeant right? Is this convienent to replace sine I am doing the other things or not really? I want to see if I can lump this in with the other repairs..
    So what's the difference with the parts I listed?
  1. Upper Intake Manifold and Lower Intake Manifold Replacement/Overhaul, due to leaks
    By McFly1999 in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 12-29-2011, 03:25 AM
  2. lower intake manifold job
    By bps02gtp in forum General Tech Discussion
    Last Post: 06-24-2011, 10:22 PM
  3. Lower Intake Manifold
    By stlmo_gtp in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 06-14-2009, 10:44 PM
  4. Lower intake manifold
    By FuglyGTP in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 03-06-2009, 10:40 AM
  5. leaking intake manifold
    By chrizzle17 in forum General Tech Discussion
    Last Post: 01-09-2009, 11:30 AM
