Thread: Lower Intake Manifold
Results 1 to 7 of 7
  1. #1 Lower Intake Manifold
    GTX Level Member stlmo_gtp's Avatar
    St. Louis
    Ok so tom. i am going to be putting on my LIM along with some other goodies, but i just noticed tonight, where the yellow o-rings go, the holes are filled and am curious if i am going to run into any problems with them being welded over?
  2. #2 Re: Lower Intake Manifold
    Jersey
    wait the hole where the coolant elbow goes is filled? You need the hole(s) where the upper coolant elbows go. There is a hole on the LIM and one on the water pump.
    16' wrx sti- stock
  3. #3 Re: Lower Intake Manifold
    St. Louis
    no not those ones these i am speaking about the ones i outlined in the pic
  4. #4 Re: Lower Intake Manifold
    hah, the funny thing is a lot of people fill those in which is okay to keep the coolant from the blower and throttle body, but youre actually blocking off a part of the coolant flow that goes to the rear head which will in turn let the rear head run hotter than the front one.
    here is what you need to do: open that cap on the TB side of the lim and take a dremel to it and open it up a little more. this will let the coolant flow to the rear head be opened up a little more since you blocked it off from the top side. id show you pictures of mine if i had any and im not taking mine apart to take any.
  5. #5 Re: Lower Intake Manifold
    St. Louis
    thanks man i know exactly what you are talking about, i think i may try to open the holes back up. the lim came like that when i bought it but just now noticed it
  6. #6 Re: Lower Intake Manifold
    Banned - Busted For Scamming
    Feb 2009
    dont open those holes back up, it helps with cooler tb temps. just dremel out the side like bio said or leave it alone, ive been runnin with them welded for a while now no problem
  7. #7 Re: Lower Intake Manifold
    St. Louis
    alright thanks for the advice looks like i will keep the holes closed and just open up the sides a bit
  1. Replies: 84
    Last Post: 09-09-2015, 08:10 PM
  2. Intake manifold :)
    By TheGreatGatsby in forum 3.1L V6 (LHO/LG8)
    Last Post: 10-03-2009, 05:16 PM
  3. Lower intake manifold
    By FuglyGTP in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 03-06-2009, 10:40 AM
  4. Intake manifold
    By joesforspeed in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 10-25-2008, 12:15 PM
