Thread: lower intake manifold might be leaking...
Page 3 of 6 FirstFirst 12345 ... LastLast
Results 41 to 60 of 103
  1. #1 Re: lower intake manifold might be leaking...
    GT Level Member andremike's Avatar
    Nov 2009
    chicago
    I haven't pulled the trigger on this but I think I might have to.... I need to check my fluids to make sure they are still ok. I noticed a faint burning smell.. I think it might be coolant burning on the side of the engine.. but not sure..
    I read that othr people replace the PCV and the injector o rings? Is that somehing I should as well? What about the water pump?
  2. #2 Re: lower intake manifold might be leaking...
    injector o-rings yes. PCV only if it hasnt been done for a while.
  3. #3 Re: lower intake manifold might be leaking...
    Nov 2009
    chicago
    Which PCV?
    ACDELCO Part # CV892C
    or
    ACDELCO Part # 89017274
    or
    ACDELCO Part # 2142296
    I wonder how much more it will cost to replace this on my car... what about the water pump?
  4. #4 Re: lower intake manifold might be leaking...
    Nov 2009
    chicago
    Which O ring? I see there are upper sets and lower sets...
    ACDELCO Part # 217452
    I think I need to buy 10 of these
    or
    ACDELCO Part # 2173366
    or
    FEL-PRO Part # ES71190
    anyone want to buy this car when I'm done?
  5. #5 Re: lower intake manifold might be leaking...
    Nov 2009
    chicago
    Where are the injector O rings when you are already replacing the LIM and UIM. Is it easy to do?
  6. #6 Re: lower intake manifold might be leaking...
    Nov 2009
    chicago
    I don't think the PCV has ever been changed..
  7. #7 Re: lower intake manifold might be leaking...
    Any pcv that fits will be fine.
    It's two 10mm bolts. Very easy to do.
  8. #8 Re: lower intake manifold might be leaking...
    Here's a thread with tons of gasket etc info in it.
    ES70599 should work, but I didn't see what year your car is...that may change the part.
  9. #9 Re: lower intake manifold might be leaking...
    Nov 2009
    chicago
    2000 Natural...
    Here is what Rockauto shows. Is there an upper and a lower?
    FEL-PRO Part # ES71190 Set Of 4
    Lower set; Injectors to cylinder head
    B
    $3.46 $6.92
    FEL-PRO Part # ES71192 Set
    Upper set; Injectors to fuel rail
  10. #10 Re: lower intake manifold might be leaking...
    Nov 2009
    chicago
    seems like the longer I wait the more parts people are recommending replacing...
    did I mention I have to also replace my front left wheel bearing for the second time.. Hopefully under warranty
  11. #11 Re: lower intake manifold might be leaking...
    i just picked up a set of o rings from harbor freight for 10 bucks, it has 10 O rings of 25 different sizes of O rings, fuel rated too.
    i plan on using them for my injectors. i only bought the pack for (1) fuel line O ring i lost on a friends truck, so it works out good in the long run for me, and they were free....
  12. #12 Re: lower intake manifold might be leaking...
    Nov 2009
    chicago
    Does anyone know the difference with the parts I listed above? Anything else I should replace? I want to buy these parts...
  13. #13 Re: lower intake manifold might be leaking...
    GTX Level Member bps02gtp's Avatar
    Nov 2010
    Illinois
    MS98014T thats the part number for the gasket set. get that, UIM gasket with a new UIM like stated previously. new thermostat, fresh oil for a change. fresh coolant. coolant elbows. and valve cover gaskets with the grommets. THATS IT
  14. #14 Re: lower intake manifold might be leaking...
    Nov 2010
    Illinois
    the LIM gasket kit comes with injector orings...
  15. #15 Re: lower intake manifold might be leaking...
    Nov 2009
    chicago
    Ill have to look.... are you sure it comes with the fuel injector o rings? Upper and lower? I was also adding the pcv valve..
  16. #16 Re: lower intake manifold might be leaking...
    Take a look at the picture in the link
    Buy Felpro Intake Manifold Gasket Set MS 98014 T at Advance Auto Parts___
    That's what comes in the gasket set mentioned. Has 6 fuel injector o-rings. They expect you won't be pulling them out of the rail. In reality if you have a 2000 then you may want to replace all 12 of them based on age. Part is ES70599, there are 4 rings per package.
    Looking at the picture..let's name the gaskets, in case anyone isn't sure what piece belongs where:
    Top metal gasket - one side of lim to head gasket
    Left side outer - 98+ engine end seal with locating pins. This sits under the driver or passenger end to seal the LIM to the block.
    Left side right of outer - 96-97 engine end seal without locating pins. This sits under the driver or passenger end to seal the LIM to the block. Blue in color. Will not be used on your motor
    Tube - RTV for the corners were the head to lim and block to lim gaskets meet.
    Four o-rings in top row - One should be pcv, two for the coolant elbows (get new elbows), last may be back of L36 manifold vaccum hose to brake booster.
    Big ring top row - Appears to be a thermostat seal (goes around stat)
    Bottom o-rings - six fuel injector o-rings
    Bottom right paper gasket - thermostat housing. used only on pre 2000 engines. Will not hurt to be used oon a 2000+. Many 00+ seep from the thermostat housing.
  17. #17 Re: lower intake manifold might be leaking...
    Nov 2009
    chicago
    Now I read that the Dorman coolant elbows are junk and break. Should I buy genuine OEM? alot more expensive, but fine...
    here are the GM part numbers: elbow to intake, part# 24503423
    elbow to water pump, part# 12565082
  18. #18 Re: lower intake manifold might be leaking...
    Nov 2009
    chicago
    It looks like this is the part that will fit for the upper injector o ring
    Part No. ES 71192
    Now the reviewes for the MS98014T say it comes with the upper o rings, not the lower... so confused..
  19. #19 Re: lower intake manifold might be leaking...
    Then stop fuggin asking us what the part number is lol. Clearly you looked it up, you double checked it. That is what you should do and that's the best thing in reality. But even Santa doesn't check his list as many times as you've done here.
  20. #20 Re: lower intake manifold might be leaking...
    Nov 2009
    chicago
    LOL... Its only after you guys point this stuff out that I do a little more research... Now what about thos coolant elbows and I think I am good to go...
  1. Upper Intake Manifold and Lower Intake Manifold Replacement/Overhaul, due to leaks
    By McFly1999 in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 12-29-2011, 03:25 AM
  2. lower intake manifold job
    By bps02gtp in forum General Tech Discussion
    Last Post: 06-24-2011, 10:22 PM
  3. Lower Intake Manifold
    By stlmo_gtp in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 06-14-2009, 10:44 PM
  4. Lower intake manifold
    By FuglyGTP in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 03-06-2009, 10:40 AM
  5. leaking intake manifold
    By chrizzle17 in forum General Tech Discussion
    Last Post: 01-09-2009, 11:30 AM
