Thread: What gives the L36 Higher Compression?
Results 1 to 20 of 28
  1. #1 What gives the L36 Higher Compression?
    GTP Level Member BlackGT97's Avatar
    Jul 2011
    Michigan
    I realize there are several different ways to achive higher compression. And seems how I never Got into the internals of the 3.8 (yet), How did GM go about this? And if the connecting rods are different lengths between the L36 and L67, How is the stroke the same? I thought It would have been different stoke lengths.
    1997 Grand prix GT Black Coupe- The beater
    1998 Grand prix GT Black coupe- Top swapped, XP cam
    2008 Grand prix Midnight blue- The slow but nice car
    1999 Chevrolet Silverado red ext. Cab
  2. #2 Re: What gives the L36 Higher Compression?
    GTX Level Member asite57's Avatar
    Oct 2011
    Michigan
    i though it was in the PCM because you can just top swap to an L67 i mean this is a really good question and id love to know the real answer
    Ohio
    Quote Originally Posted by asite57 View Post
    Noo..
    Compression is in the pistons and combustion chamber.
  4. #4 Re: What gives the L36 Higher Compression?
    Poppin 'em thangs mechguy's Avatar
    Dec 2010
    Canada
    I think its due to the rod length. If it is, then:
    Longer rods allow the piston to travel further toward the head, increasing compression. So why doesn't the stroke change? This is because the longer rods don't allow the pistons to receed as far into the bottom of the cylinder as the L67.
  5. #5 Re: What gives the L36 Higher Compression?
    Oct 2011
    Michigan
    so why can you just swap the top over and call it good?
    Ohio
    That too ^^
  7. #7 Re: What gives the L36 Higher Compression?
    Jul 2011
    Michigan
    so the l67 goes down further and the l36 goes up further, therefore having the same stroke?
  8. #8 Re: What gives the L36 Higher Compression?
    Dec 2010
    Canada
    I don't understand what you are asking.
    A top swap retains the formerly NA block and heads.
  9. #9 Re: What gives the L36 Higher Compression?
    Dec 2010
    Canada
    Quote Originally Posted by BlackGT97 View Post
    Yes sir.
    At least that is my intuition. I've never checked into it.
  10. #10 Re: What gives the L36 Higher Compression?
    Oct 2011
    Michigan
    ive never done a top swap, i though you swaped over the l67 heads up and left the NA block. im just trying to get a better understanding not sound like i know what im talking about
  11. #11 Re: What gives the L36 Higher Compression?
    Jul 2011
    Michigan
    You can't topswap and call it good. You have to tune for it. Having the higher compression and Boost causes more heat, which causes detonation. Flow mods, cooler plugs, and cooler air (intercooler) and tuning, are all ways to fight the detonation, AKA knock.
  12. #12 Re: What gives the L36 Higher Compression?
    As far as I know its the piston.
    As in the dish size. Dish CC unknown, but around 10 cc for 8.5 CR and 4-5 cc for 9.4 CR IIRC.
    The rod length is related to the different wrist pin location in the piston. Somewhere in the mid low 5" "total length", center-to-center is under 5" IIRC.
    The CC in the heads are the same too. At one point the casting was the same with some extra machine work to add the injector bungs for the L67. 64 cc IIRC.
    Only absolute number here I'm sure of is the combustion chamber number from intense.
    On the top swap concept: you'll need headers to run a 3.8 pulley.
  13. #13 Re: What gives the L36 Higher Compression?
    Jul 2011
    Michigan
    The heads, in the mechanicale aspect are the same. Only thing different is the port for the injectors. So your Pushrods, lifters, open the valves just as far as they would with the N/A heads.
  14. #14 Re: What gives the L36 Higher Compression?
    The Boss Iceman6669's Avatar
    Jun 2011
    Quote Originally Posted by mechguy View Post
    As long as the stroke doesn't change then that doesn't change the compression. You will always start at 0 PSI on the intake stroke. Then no matter where the pistons stops if it makes the same stroke then it should make the same compression. Or my logic could be wrong.
    2011 F-150 Yote powered
  15. #15 Re: What gives the L36 Higher Compression?
    Dec 2010
    Canada
    Quote Originally Posted by Iceman6669 View Post
    No sir.
    Imagine this: A 10 foot long cylinder with the same stroke as your engine. There would be almost no compression in the former.
  16. #16 Re: What gives the L36 Higher Compression?
    Jul 2011
    Michigan
    ^^^True. This right here is a good comparison.
    Mercer, Pa
    Piston wrist pin to top of piston length is different. L67/L32's have more valve clearance.
    The rods may be same length but the wrist pin ends are different and specific to the piston.
  18. #18 Re: What gives the L36 Higher Compression?
    Federal-Mogul Resource Center - Part Details
    The S/C pistons have larger pins.
    Compression distance is greater for s/c pistons which means you'd have to have a shorter rod to have the same piston/valve clearance.
  19. #19 Re: What gives the L36 Higher Compression?
  20. #20 Re: What gives the L36 Higher Compression?
    Oct 2011
    Michigan
    so what a L36 top swapped to an L67 be faster than a stock L67?
  1. No compression
    By carbon in forum General Tech Discussion
    Last Post: 12-22-2011, 09:12 PM
  2. high compression, low boost. lower compression, higher boost
    By BlackGT97 in forum General Tech Discussion
    Last Post: 08-25-2011, 11:52 AM
  3. Compression Test
    By RedGrandPrix in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 07-28-2009, 10:38 PM
  4. compression check
    By justwhisen in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 07-06-2009, 10:09 PM
  5. Bad Compression?
    By comongoose in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 02-24-2009, 01:22 AM
