Thread: What gives the L36 Higher Compression?
Results 1 to 20 of 28
  1. #1 Re: What gives the L36 Higher Compression?
    Federal-Mogul Resource Center - Part Details
    The S/C pistons have larger pins.
    Compression distance is greater for s/c pistons which means you'd have to have a shorter rod to have the same piston/valve clearance.
  2. #2 Re: What gives the L36 Higher Compression?
    My searching suggests the L67 pistons must have a larger dish in order to lower compression and increase piston-valve clearance.
  3. #3 Re: What gives the L36 Higher Compression?
  1. No compression
    By carbon in forum General Tech Discussion
    Last Post: 12-22-2011, 09:12 PM
  2. high compression, low boost. lower compression, higher boost
    By BlackGT97 in forum General Tech Discussion
    Last Post: 08-25-2011, 11:52 AM
  3. Compression Test
    By RedGrandPrix in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 07-28-2009, 10:38 PM
  4. compression check
    By justwhisen in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 07-06-2009, 10:09 PM
  5. Bad Compression?
    By comongoose in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 02-24-2009, 01:22 AM
