Thread: high compression, low boost. lower compression, higher boost
Results 1 to 5 of 5
  1. #1 high compression, low boost. lower compression, higher boost
    GTP Level Member BlackGT97's Avatar
    Jul 2011
    Michigan
    lets hear the opinions (or facts ). which one is better for speed/accel. and which one for top end ?
  2. #2 Re: high compression, low boost. lower compression, higher boost
    I'd prefer low compression, more timing and boost. Less chance of popping a piston I think. But it really would come down to the tune.
  3. #3 Re: high compression, low boost. lower compression, higher boost
    GT Level Member Tommyp2010's Avatar
    Poland, Ohio
    agreed, plus it's fun to tell people that you're running 23 psi of boost. In the end, lower compression is the "right" way of doing it, hence why FI cars come with lower compression from the factory, more reliable.
    2006 Mitsubishi Evo IX MR
  4. #4 Re: high compression, low boost. lower compression, higher boost
    GTP Level Member 01gpgt01's Avatar
    Hagerstown,Md
    Higher compression for the POS m90, Anything else with a decent FI set up lower compression, but to answer your question if its pertaining to the m90 then higher will win hands down.
    2001 GT. A few here and there mods http://www.streetfire.net/video/2001...ynp_208097.htm
    2009 Hummer H3 Solar flare premium
  5. #5 Re: high compression, low boost. lower compression, higher boost
    I <3 my low compression...granted it is higher than the factory 8.5:1...but it isn't quite near what a N/A motor makes...9.4:1.
    A higher compression motor (if we are comparing apples to apples on pump high octane, say 93) can't run as much boost and timing as a low compression motor...BUT...the higher compression makes up for that extra boost you need to make with the low comp. motor to make the same numbers...high comp. motor will make more power out of boost and won't have as much parasitic loss as a high boost, low comp. motor would...nor would you take the risk of such high a timing car like a low comp. high boost car...but then a high comp motor that is boosted runs the risk of popping a piston easier IMO, spot on tunes would cure that but if your tune isn't accurate...it's a damn ticking time bomb.
  1. Overheated, Low Compression Cyl #3
    By mojonba in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 02-18-2011, 10:38 AM
  2. GTP with misfire at higher rpms or when boost starts to kick in
    By 00obgtp in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 09-14-2009, 05:27 PM
  3. compression check
    By justwhisen in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 07-06-2009, 10:09 PM
  4. Compression Check?
    By 99prixgt in forum General Tech Discussion
    Last Post: 06-09-2009, 11:01 AM
  5. Bad Compression?
    By comongoose in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 02-24-2009, 01:22 AM
