Thread: What gives the L36 Higher Compression?
Page 2 of 2 FirstFirst 12
Results 21 to 28 of 28
  1. #21 Re: What gives the L36 Higher Compression?
    Quote Originally Posted by asite57 View Post
    so what a L36 top swapped to an L67 be faster than a stock L67?
    Considering you'd have to run headers or a cam or intercooler just to run the 3.8, yes.
  2. #22 Re: What gives the L36 Higher Compression?
    My searching suggests the L67 pistons must have a larger dish in order to lower compression and increase piston-valve clearance.
  3. #23 Re: What gives the L36 Higher Compression?
  4. #24 Re: What gives the L36 Higher Compression?
    A top swapped l36 on a stock pulley is supposed to be like an l67 on a 3.4 pulley
  5. #25 Re: What gives the L36 Higher Compression?
    It was still slow.
    I should have dyno'd it so we would have had solid information.
    Ohio
    Yeah something was definitely off with your top swap matt. I couldn't understand why you were barely making the true power
  7. #27 Re: What gives the L36 Higher Compression?
    it made 267 STD on a 3.4 pulley with rockers at 5200-5500 est RPM.
    Never took it higher because I failed to hold the car in third.
    With leaky valves and some odd compression numbers while churning out liquid metal every oil change.
    Ohio
    Ahhh I see. I didn't know about the oil problem
  1. No compression
    By carbon in forum General Tech Discussion
    Last Post: 12-22-2011, 09:12 PM
  2. high compression, low boost. lower compression, higher boost
    By BlackGT97 in forum General Tech Discussion
    Last Post: 08-25-2011, 11:52 AM
  3. Compression Test
    By RedGrandPrix in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 07-28-2009, 10:38 PM
  4. compression check
    By justwhisen in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 07-06-2009, 10:09 PM
  5. Bad Compression?
    By comongoose in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 02-24-2009, 01:22 AM
