Thread: need some intake help
Results 21 to 40 of 52
  1. #21 Re: need some intake help
    So just open cone that ugly broad
    the filter hits all the abs crap. even the long thinner cone. i did a dry test at the parts store where i bought the one i wound up with. then went and got all the tubes and clamps at the home depot.
  2. #22 Re: need some intake help
    GT Level Member GTLGDP's Avatar
    Oct 2011
    New Jersey
    Like do i need a certain filter size? Or whats needed to bolt it on correctly? I'm new to all this it just confusing to me without a guide of some sort.
  3. #23 Re: need some intake help
    Quote Originally Posted by GTLGDP View Post
    Link in signature guy.
    Has all the info you need.
  4. #24 Re: need some intake help
    the filters usally come with a 4 inch opening and a 3 inch adapter to make it fit either size, the pvc pipe i belive was 3 inch pipe, but the one side is 4 inches because its fatter to let a 3 inch pipe slide into it and be sealed in its original use it was intended for.
    note how one side is fatter, thats the 4 inch side, the thin side matches the t body.this is how i painted mine too.
  5. #25 Re: need some intake help
    That is the best gutter setup I've ever seen
  6. #26 Re: need some intake help
    lol thats hanging off my 7 th floor balcony, its clipped to the 8 th floor balcony metal trim work. nice view huh? got a 7-11 across the street too.
  7. #27 Re: need some intake help
    Oct 2011
    New Jersey
    If i had open cone it would hit all of this **** i'm pretty sure. Unless i'm just stupid, in that case, please excuse my stupidness.
    Ohio
    Your abs module is sideways from what mine is. It shouldn't hit that though
  9. #29 Re: need some intake help
    With that tiny little filter you have...I doubt it.
    Get rid of all that restrictive, tiny pipe you got there...and go to auto zone and get a 6" Spectre Filter...whatever color you want...and toss it on the end of the TB...
  10. #30 Re: need some intake help
    Oct 2011
    New Jersey
    The air filter on it right now is 9". Where does the temperature sensor go if all the tubing is gone?
  11. #31 Re: need some intake help
    In the filter
  12. #32 Re: need some intake help
    Oct 2011
    New Jersey
    In the filter? I don't exactly understand what you mean lol do you have a picture or something?
    The Boss Iceman6669's Avatar
    Jun 2011
    Just tuck it inside when you slap it on the tb... My does touch the abs thing a little but not too much.
    2011 F-150 Yote powered
  14. #34 Re: need some intake help
    Oct 2011
    New Jersey
    So slip it inside the filter, then put the filter on the tb just dangling in there?
  15. #35 Re: need some intake help
    Jun 2011
  16. #36 Re: need some intake help
    Jun 2011
    then just tuck the sensor inside the filter a bit...
  17. #37 Re: need some intake help
    Oct 2011
    New Jersey
    gotcha, thanks.
  18. #38 Re: need some intake help
    Jun 2011
    right on....
  19. #39 Re: need some intake help
    I get it.
    I learn good with coloring books too
  20. #40 Re: need some intake help
    GTX Level Member asite57's Avatar
    Oct 2011
    Michigan
    what is the IATand how important is it if i just left it dangling
  1. Upper Intake Manifold and Lower Intake Manifold Replacement/Overhaul, due to leaks
    By McFly1999 in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 12-29-2011, 03:25 AM
  2. Short Ram Air intake or Cold Air Intake
    By slopez in forum General Tech Discussion
    Last Post: 02-01-2011, 10:08 PM
  3. Coolant Loss, intake Gasket or Intake Itself???
    By WoR in forum General Tech Discussion
    Last Post: 04-29-2009, 04:02 PM
  4. ram air intake
    By jprovinsal in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 02-11-2009, 08:17 AM
