Thread: Car seems slow in second gear..vids....and an update...sort of.
Page 3 of 3 FirstFirst 123
Results 41 to 59 of 59
  1. #41 Re: Car seems slow in second gear..vids.
    Never Never Land
    What should the compression be? My dad had a gauge to test. I could just compare mine to the factory spec and that should be ballpark
  2. #42 Re: Car seems slow in second gear..vids.
    180 would be nice.
    above 100 psi is "acceptable".
  3. #43 Re: Car seems slow in second gear..vids.
    4 th in your vid the car seems to short shift a bit, where brandons seems to really have the grunt sound of digging into the trans harder, and shifting a bit later.
    the way brandons sounds is why i like GM cars better than ford or Chrysler, they seem to just drive when going wot,(they lack a good kick down it seems to me) where a GM cars have that digging into the trans grunt that you can feel.
    brandon, are you running a open cone? your sc sounds a lot louder than 4 th's.
  4. #44 Re: Car seems slow in second gear..vids.
    Never Never Land
    Quote Originally Posted by 4THGENCAMAROFAN View Post
    I'd also just like to point out that it seems like Brandon's shifts at a little bit higher RPM. At leat it looks like it to me.
    I was thinking the same thing. Brandon has an open cone i believe. I know it's not a factory intake but I don't know what it consists of.
  5. #45 Re: Car seems slow in second gear..vids.
    Grand Rapids, MI
    i know exactly what you mean, my grandparents really like chrysler and the kick downs suck. they kinda hesitate for the kick downs as well. you floor it and it goes "oop! wait a seconddddd, hold itttt, OKAY GOOO....sort of"
    but yeah, this is my intake setup. sounds good doesn't it
    http://i96.photobucket.com/albums/l1...0/0e7f7ab1.jpg
  6. #46 Re: Car seems slow in second gear..vids.
    Banned
    Mansfield, Ohio
    Quote Originally Posted by brandonl2000 View Post
    i can do the test if you like buddy i want you to be able to get your car right.
    my money is on the trans too but ya never know.
    but $42 is one thing as well.
    and eric. how in the hell are you gonna let us borrow the tester all the way from backwoods ohio??
    Umm ship it to you? Umm you ship back when your done?
  7. #47 Re: Car seems slow in second gear..vids.
    you can rent a compression tester from pep boys for free, you basically buy it, when you bring it back they give you a full refund, you've got 24 hours to use it.
  8. #48 Re: Car seems slow in second gear..vids.
    Grand Rapids, MI
    Quote Originally Posted by cleangtp View Post
    mk well ill let austin make the decision it's up to him
  9. #49 Re: Car seems slow in second gear..vids....and an update...sort of.
    Never Never Land
    Updated the first post with another video and some more info.
  10. #50 Re: Car seems slow in second gear..vids....and an update...sort of.
    Grand Rapids, MI
    Hm, yeah I see the laggy reverse, but it isn't THAT bad. And it's not slipping in WOT, it's just slow, so deal with it for now. And you talk too much, stfu and put it in gear already lol.
    But yeah, unless you're planning on going WOT the whole way to kcgp, stfu. I expect to see you then. That is all
  11. #51 Re: Car seems slow in second gear..vids....and an update...sort of.
    Never Never Land
    If I get into throttle more it gets worse..I just don't wanna break anything cuz I can't imagine it being good for the trans lol. And i belive it's is somewhat slipping thus causing it not to be as fast....this sleeve or whatever bleeds of pressure...so if it bleeds of pressure then it's basically not fully engaging and it's not going to be as fast. At least that's how I understand it.
  12. #52 Re: Car seems slow in second gear..vids....and an update...sort of.
    you know your tach bounces when the cars off right?
  13. #53 Re: Car seems slow in second gear..vids....and an update...sort of.
    Never Never Land
    Ya it does it sometimes..doesn't others. I haven't had a problem since I changed the crank sensor so what ev.
  14. #54 Re: Car seems slow in second gear..vids....and an update...sort of.
    Grand Rapids, MI
    okay, good, i thought i was crazy or the camera was weird.
    that's strange though. it's a 97 though so i dont doubt anything!
  15. #55 Re: Car seems slow in second gear..vids....and an update...sort of.
    I've watched all those videos of all those slow stock cars like 90 times.
    Austin...seriously looks normal to me...I think a tune and a shift kit will change it all around.
    I don't see this 4 second delay in the shift Matt is talking about...looks like it is just shifting without Performance Shift on even though it is engaged...that's all.
  16. #56 Re: Car seems slow in second gear..vids....and an update...sort of.
    Grand Rapids, MI
    More the reason you have to suck it up and come to kcgp, Austin!
  17. #57 Re: Car seems slow in second gear..vids....and an update...sort of.
    Never Never Land
    I think Matt means 4 seconds from the shift till the end of the pull..or something like that.
    And Nick i'm tellin you...second gear just sucks. I've driven a few other GTP's and they ALL have a much firmer, quicker shift and pull better once in second gear.
  18. #58 Re: Car seems slow in second gear..vids....and an update...sort of.
    I'm tellin' ya...converter could be goin' out...transmission could just be getting old...but it is SHIFTING fine is what I'm getting at. If it is doggy in the middle of the gear, what would the transmission have to do with that since it has already shifted? I told ya too...the '97-'98 intake is way more restrictive...and the '03's have Performance shift tabled into the PCM via throttle response...and it always seemed that my '03 shifted better/faster than my buddy who had a '98 with Perf. Shift...I would always nose out on him even when I was stock and he had a intake/u-bend delete.
    Get your headers on and get a tune.
    And a shift kit.
    It'll fix it.
  19. #59 Re: Car seems slow in second gear..vids....and an update...sort of.
    i think blues on to the answer here. and your trans does seem to not be on perf shift, as it short shifts a little bit.
    my 98 regal shifts at 5800 to or a little more, if i hold it to the floor in drive. mines old and tired. i like to pedal shift it closer to 5500, i hate a screaming engine thats not going anywhere
  1. 2nd gear to 4th gear shift
    By 98grannyprix in forum 1997-2007 4 speed Automatic (4T65E) (4T65E-HD)
    Last Post: 09-17-2011, 01:03 AM
  2. new vids
    By IR II IP IDEATH in forum Off Topic Discussion
    Last Post: 06-05-2011, 08:20 PM
  3. GTP vs G8 *vids*
    By Lawngoose in forum Track Sessions and Kills
    Last Post: 10-19-2010, 03:53 PM
  4. More Vids ;)
    By blueguy in forum Track Sessions and Kills
    Last Post: 05-16-2009, 07:25 PM
  5. Gear selector is a gear off after rebuild
    By skalor in forum 1997-2007 4 speed Automatic (4T65E) (4T65E-HD)
    Last Post: 08-17-2008, 11:08 PM
