are your window tracks bent?, actually sounds like the front or rear of the windown isnt between the channels properly.
Thank you, Im going to check it out on my next day off and I have been seeing a lot threads saying to clean the switch connections and lube the tracks and such.
98GTP 3.5in tips, headers, fenderwell intake, 180tstat...3.5pulley?
1984 Four Winns (Boat) 190 Horizon 19ft open bow...new 350 soon! and Thru Hull exhaust!
03-07 Duramax Diesel next summer after paramedic is finally over!
#2
Re: Just replace window regulator with motor and...
try not to use grease to lube the track or regulator, it attracts dust and dirt, try to use graphite. i bought some in a spray can, works great, make your locks feel better than new.
