Thread: lim gasket leaking
Results 1 to 7 of 7
  1. #1 lim gasket leaking
    AL
    so i bought another gtp on sunday, and noticed today it is leaking coolant from the lim.. not a huge deal to me but i have a couple questions...
    this is not a stock gtp, its a 98 with a 05 gt block, top swaped, top end is still 98, has a s1x cam, ls7 springs, speed daddy's, and a 3.5 pully.
    with that being said on to the questions...
    everything i read says no plastic gaskets, but the fel pro kit i am looking at has plastic-rubber end seals, is there a better one for what the car has done to it?
    next.. do i get the kit for the 05 or for the 98? dident think it would matter considering it is all bolted together, but wanted to make sure.
    last.. is there anything else i should go ahead and do while im in there?
    the block has 43k mi on it and the heads have 10k the s/c has 157k.
    i think the only reason its leaking is it was not sealed quite right when the top swap was done..
    thanks in advance for any help on this..
  2. #2 Re: lim gasket leaking
    Where's the leak? You say LIM, but that could mean the end cover (small gasket by itself) etc.
  3. #3 Re: lim gasket leaking
    AL
    is leaking on the driver side, coming from the the end of the lim. the lim has to be pulled to relace that end seal correct? thus having to replace the actual lim gaskets?
  4. #4 Re: lim gasket leaking
    I live here. TLSheff's Avatar
    Quote Originally Posted by jayn View Post
    ...everything i read says no plastic gaskets, but the fel pro kit i am looking at has plastic-rubber end seals, is there a better one for what the car has done to it?
    You were probably looking at the original replacement, which is Plastic with rubber seals. You want the Felpro Gasket # MS98014T, "Problem Solver" gasket, it's metal with rubber seals. You will also need a Supercharger gasket, possibly TB gasket depending on how far you tear it apart, theres actually a full list of everything you need to do it somewhere around here...
  5. #5 Re: lim gasket leaking
    AHA!!! found it... took some searching skills but I found everything you need to do the job
    Read this http://www.grandprixforums.net/video...utes-3112.html
    Pay particular attention to Post #13 by TMC.... everything you need and stepped instructions for doing it... or watch the video in the link in Post #1 if you want the easy way out
    EDIT: BTW ive done it 2xs now... it looks harder than it is, but you can do it with most basic auto tools and a good open saturday
  6. #6 Re: lim gasket leaking
    AL
    yeah thats the p/n im looking at, i was just wondering about the plastic-rubber end seals it comes with.. thank you for the part number though, at least i know im looking at the right kit... so i guess the 98 top 05 block thing dosent matter?
  7. #7 Re: lim gasket leaking
    AL
    awsome! thank you for that! its not doing it i have the issue with, thats no problem.. just wanted to make sure i am getting the correct parts and the best ones i can get... i see no reason to have to do this again in 6 months... thanks again
  1. Leaking intake manifold gasket
    By egloskerry in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 05-03-2011, 01:58 AM
  2. Leaking Oil ?
    By Blacknight02GT in forum General Tech Discussion
    Last Post: 12-30-2010, 11:29 AM
  3. LIM Gasket, Head Gasket, or bad sensor?
    By GTFiske in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 10-04-2010, 08:40 PM
  4. s/c gasket leaking setting p0171
    By nascartech in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 07-28-2010, 04:56 PM
  5. Gasket/Leaking problem
    By Phil_GTP in forum 3.4L V6 (LQ1) DOHC
    Last Post: 10-13-2008, 01:48 PM
